97 Powerstroke Brake Lights and Third Brake Light Not Working - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 02-10-2013, 04:53 PM Thread Starter
Adinas95's Avatar
Hello Guys,
I recently bought a 1997 f350 powerstroke and it did not come with a bed. Ive been trying to hook up some temporary tail lights and cant figure this out. I managed to get the lights to work when you pull the light knob out but when you push the break neither brake lights work or third brake light.
I checked all fuses and none are blown also.
Any help would be great! Thanks!
Zach
1997 F350 XL DRW CC Auto 340,xxx, Glowshift Gauges, AFE Intake, TS 6 pos chip, stock exhaust with cat & Muff delete
Adinas95 is offline
post #2 of 14 (permalink) Old 02-14-2013, 10:55 PM
Re: 97 Powerstroke Brake Lights and Third Brake Light Not Working
try to search the internet for ford bronco wiring diagrams...good luck finding one for a psd.
97 ccsb 4x4. Tymar custom intake, 1.0 housing, turbo blanket, mbrp 4 in exhaust 3 in downpipe, kingpin d60 rsk, ccv mod, swamps idm mod, beans e-fuel, upgraded banjo bolts, 203* thermostat, bts valve body, external trans filter, 45k lb trans-cooler, glowshift gauges, 6 position bully dog chip, superduty-lariat seats....
Dundunitall is offline
post #3 of 14 (permalink) Old 02-14-2013, 10:57 PM
Multi function switch aka blinker switch
Sent from AutoGuide.com App
2000-7.3L is offline
post #4 of 14 (permalink) Old 02-15-2013, 02:54 AM
jbrixen's Avatar
IIRC the center stoplight bypasses the multi function switch. need to check stoplight switch input and out put, power into switch will be hot at all times.
jbrixen is offline
post #5 of 14 (permalink) Old 02-15-2013, 02:59 AM
What he said. Jbrixen, chance of being the multifuction switch?
post #6 of 14 (permalink) Old 02-15-2013, 03:13 AM
K Kinas
Slim, Brake switch more likely
PistonPin is offline
post #7 of 14 (permalink) Old 02-15-2013, 03:16 AM
If only you knew how many of those damn things iv replaced and sold.
post #8 of 14 (permalink) Old 02-15-2013, 03:16 AM
jbrixen's Avatar
if the center stoplight worked yes it could be.
jbrixen is offline
post #9 of 14 (permalink) Old 02-15-2013, 03:25 AM
jbrixen's Avatar
when i was in the auto parts scene i sold my fair share. but no ware near as many as government motors cars
the obs's dont have near as many problems as the superdutys and 97+ f150's had (think they used the same switch).
jbrixen is offline
post #10 of 14 (permalink) Old 02-15-2013, 03:32 AM
Whoa hating on the 99-03 SD's
