map sensor blow off valve - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-14-2007, 03:03 AM Thread Starter
Oil anyone?
The Oiler's Avatar
Question map sensor blow off valve
I looking for a blow off valve or boost regulator for the map sensor. I just put on a H2E, and now when I pulled it defueled on me. How do I fix this or is this a tuning issue ?
Thanks in advance
Nate
Pull truck:
96' F-250 ex-cab
Swamps oil and fuel
T-bars,airbags, 5in stacks
getting back on the road soon.
Now have a s366 from Swamps now.
01' xlt excursion with a 7.3
all stock for now and gets 18mpg
The Oiler is offline
post #2 of 16 (permalink) Old 09-14-2007, 03:17 AM
Corona Killa
THEDIESELMAN's Avatar
Re: map sensor blow off valve
I have this one and it works great and Dennis is a site sponsor
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #3 of 16 (permalink) Old 09-14-2007, 08:42 PM
Just go to Home Depot or Lowe's and get a pressure regulator like what would go on an air tank. They are like $20 or less and work great. This way to it's not just a blow off that is leaking boost to the atmosphere.
hotwheels is offline
post #4 of 16 (permalink) Old 09-15-2007, 01:24 AM Thread Starter
Oil anyone?
The Oiler's Avatar
Thanks a ton,now I can eliminate this issue.
Pull truck:
96' F-250 ex-cab
Swamps oil and fuel
post #5 of 16 (permalink) Old 09-18-2007, 08:29 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Really get the one from ITP...http://www.itpdiesel.com/store.php?c...on=show_detail
Its worth it... No hunting parts, no setting pressures, no regulator flopping around, nice, easy and clean install
Joe
CSIPSD is offline
post #6 of 16 (permalink) Old 09-19-2007, 12:27 AM
Bill
badford350's Avatar
the bracket from itp makes the kit worth it imho
02 f350 larit, itp rr & pre pump filter, GTP38r, international up pipes, swamps 175/146 single shot's, DP tuner, factory tech valve body & lot of extra lights
badford350 is offline
post #7 of 16 (permalink) Old 09-19-2007, 01:00 AM
Corona Killa
I have to agree and like CSI said you don't have to go and find parts and it comes with a mounting bracket and makes it a 5 minute job.
post #8 of 16 (permalink) Old 09-23-2007, 10:19 PM
PSN nerd
the regulators arnt as effective as the blow off valves. they dont react to the quick building boost like the blow offs will. blowing off such a little amount of boost isnt gonna noticibly effect power
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #9 of 16 (permalink) Old 09-23-2007, 10:48 PM
Corona Killa
I think the opposite of you I think the regulators are the best and what happens if the BOV get stuck open that can't be good when you aren't making much boost.
post #10 of 16 (permalink) Old 09-24-2007, 06:24 AM
Terminator Nation
Hardware store pressure regulator has been working great for 80K miles stopping turbo overboost CELs. Maybe mine isn't one of those fast boost building ones since its only got a 1.0 housing OBS turbo making 408 hp.
old man dave is offline
