tire psi - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-26-2012, 04:18 PM Thread Starter
sharpmotors's Avatar
tire psi
just wondering what kind of tire pressure you guys are running in your single wheel f350's.i am running 285's on my truck at 60 psi front and rear.
1997 f350 xlt regular cab 4x4,matercraft courser at2 285's, automatic,1.0 housing,ebpv delete housing and pedestal,tymar intake,diamond eye dp w/4 inch straight pipe,super duty starter,203* tstat
sharpmotors is offline
post #2 of 5 (permalink) Old 12-26-2012, 04:24 PM
Bugman's Avatar
Re: tire psi
Run what you want until you load the truck up then put more into them. For ride comfort I usually run 60 in the front and 55 in the rear unloaded.
Bugman is online now
post #3 of 5 (permalink) Old 12-26-2012, 04:26 PM
Administrator
Zmann's Avatar
Re: tire psi
I suggest this when not towing
Proper Tire Inflation
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 5 (permalink) Old 12-26-2012, 06:42 PM
Re: tire psi
Check the decal on the door jamb. F350/straight axle may be different, but on the F250/TTB, front MAX is 55 psi.
madpogue is offline
post #5 of 5 (permalink) Old 12-26-2012, 09:38 PM
alleged moderator
tjctransport's Avatar
Re: tire psi
that is how i was taught to check tires 50 years ago, and i have never had any problems with tire wear using that method.
tom
tjctransport is offline
