95 7.3 won't rev past 1200RPM - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 11-07-2012, 04:38 PM Thread Starter
Ok so I have a 95 cc dually 7.3 diesel that starts up and idles fine sounds good. When I put into drive or even in neutral or park it won't rev passed 1200RPM? I just replaced the IPR, CPS 3 times and oil, oil filter, no leaks anywhere IDM also replaced with 2 known good ones? Does anyone know what this could be? Is it something db I overlooking? Thanks for the help
Sent from my iPhone using Autoguide.com App
JDawg965 is offline
post #2 of 21 (permalink) Old 11-07-2012, 04:57 PM
jbrixen's Avatar
Re: 95 7.3 won't rev past 1200RPM
have you checked fuel pressure/fuel filter?
jbrixen is offline
post #3 of 21 (permalink) Old 11-07-2012, 10:07 PM Thread Starter
Fuel filter is semi new and at the fuel bowl pressure is about 50psi from the valve..
JDawg965 is offline
post #4 of 21 (permalink) Old 11-08-2012, 01:51 AM
Brian
Orangeracer's Avatar
Send a message via AIM to Orangeracer
Fuel filters would cause the problems
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Orangeracer is offline
post #5 of 21 (permalink) Old 11-08-2012, 02:44 AM
jbrixen's Avatar
use a multi meter or a scan tool to see the voltage output of your pedal position sensor(TPS). should be somewhere around under 1v at idle pos and just below 5v.
jbrixen is offline
post #6 of 21 (permalink) Old 11-08-2012, 02:48 AM Thread Starter
Ok where should I measure the voltage from on the tps, which wires..
I will check that tomorrow if this snow holds off and I will replace the fuel filter with a new one... Let me know thanks
Key on engine off for the tps test?
JDawg965 is offline
post #7 of 21 (permalink) Old 11-08-2012, 02:53 AM
jbrixen's Avatar
not sure colors but there is usually a 5v reference, signal out and a ground. soonest i can get to a wiring diagram is tomorrow morning.
jbrixen is offline
post #8 of 21 (permalink) Old 11-08-2012, 04:25 PM Thread Starter
Thanks so much, I will check later this afternoon and go from there hopefully I can find something out. I am assuming key on engine off or engine running?
JDawg965 is offline
post #9 of 21 (permalink) Old 11-08-2012, 08:19 PM
jbrixen's Avatar
KOEF "key on engine off"
jbrixen is offline
post #10 of 21 (permalink) Old 11-08-2012, 10:09 PM Thread Starter
I checked the wires and I am getting 5v but doesn't the check have to be after the tps? Bc testing tue wires before the tps is jus telling me its getting what it wants to the tps how do I verify if its working??? Here is a video check it out and let me know...
http://i128.photobucket.com/albums/p...98168348E4.mp4
JDawg965 is offline
