Fuel Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 11-07-2012, 01:26 PM Thread Starter
Fuel Leak
On my 97 F350 I noticed that there has been some fuel leaking from the drain in the bell housing. From looking on top of the engine I found that there was fuel in the valley. I believe that the source of the leak is coming from the fuel pump and I am assuming that this means that the fuel pump is going out. I am not sure what steps to take from here as I am new to the diesel world. Does anyone have any pointers of what I should do from here? Thanks for your help in advance.
jmguyas is offline
post #2 of 12 (permalink) Old 11-07-2012, 01:41 PM
mroutlawoffroad
OUTLAW-OFFROAD's Avatar
Re: Fuel Leak
Might just need new brings on the fuel bowl common problem.
96 cclb 10" lift 38" tires.
6 pos custom tuned chip, AD injectors, hoodstack, fpr shim,isspro gauges, electric fans, Built trannismission.
OUTLAW OFFROAD traction bars.
OUTLAW-OFFROAD is offline
post #3 of 12 (permalink) Old 11-07-2012, 01:42 PM
mroutlawoffroad
Re: Fuel Leak
Auto correct. Ment to say new O Rings
post #4 of 12 (permalink) Old 11-07-2012, 02:56 PM Thread Starter
Re: Fuel Leak
Can I determine this without taking out the fuel pump or does that have to come off?
jmguyas is offline
post #5 of 12 (permalink) Old 11-07-2012, 03:19 PM
Certified Engine Destroye
treetechsixOH's Avatar
Re: Fuel Leak
Just try the drain back valve orings. Roughly 40 bucks from your local Ford dealer.
___________________________________
03 CCSB Lariat 350 SRW
Built by me @ Outlaw Diesel Performance
Warren/K&N/Deleted/Exhaust, few other goodies.
Studs, SCT, Nitrous Express, ODP RR, Custom Fuel waiting for install.
treetechsixOH is offline
post #6 of 12 (permalink) Old 11-07-2012, 03:23 PM
pappa b's powerstroke's Avatar
Re: Fuel Leak
i use a good flashlight and one of those telescoping mirrors from the parts store to find fuel leaks. you can look at the fuel bowl and lines with the engine running and see where it drips. the rubber lines are prone to leaking after many miles and years, also the sensor that screws into the back of the fuel bowl might leak. i'd dry out the valley real good and pin point the leak before you start unbolting stuff. good luck!
2002 f350 srw automatic 3:73 gears,
a/c that works!
pappa b's powerstroke is offline
post #7 of 12 (permalink) Old 11-07-2012, 05:43 PM Thread Starter
Re: Fuel Leak
I have looked very closely with a flashlight and it apears that the drip is coming from the fuel pump rather than the fuel bowl.
jmguyas is offline
post #8 of 12 (permalink) Old 11-08-2012, 01:54 AM
Brian
Orangeracer's Avatar
Send a message via AIM to Orangeracer
Re: Fuel Leak
I would use a rag or paper towels an dry it all then pin point the leak
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Orangeracer is offline
post #9 of 12 (permalink) Old 11-08-2012, 02:42 AM
1997 F350 CCLB
Re: Fuel Leak
X2 with cleaning it up, using a mirror and a flashlight while the engine is running. To figure out where the leak is coming from.
teevo20 is offline
post #10 of 12 (permalink) Old 11-08-2012, 03:21 AM
ved0303's Avatar
Re: Fuel Leak
I rebuilt my fuel bowl with all new o-rings and it still leaked fuel. Turned out it was the fuel filter vacuum switch which is on the fuel bowl. Apparently its a common problem. Costs about 50 bucks at the dealership.
1997 F250 HD, E4OD to ZF5 conversion, warn manual hubs, otherwise stock for now...
ved0303 is offline
