Water Pump/Thermostat ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 11-07-2012, 04:01 AM Thread Starter
1997 F350 CCLB
My water pump is begining to leak, I was wondering what water pumps you guys have used? Which one you think is best?
Also I was wondering which thermstat is best to use for my 7.3? I was thinking the 203 degree one, but whats your guy's opinions??
teevo20 is offline
post #2 of 7 (permalink) Old 11-07-2012, 09:23 PM
Re: Water Pump/Thermostat ?'s
I replaced mine last spring with one from NAPA. Works fine. I used the 192 degree. I changed to the 203 last week. Heater works better in cold weather. At least in mine it does. I bought my thermostats fro Ford.
msscatter is offline
post #3 of 7 (permalink) Old 11-08-2012, 12:21 AM
blageurt's Avatar
If I had an F-series I would do the International pump with the filter in a minute....
In a Van it is a retarded amount of work for the rad plumbing.... I bought all Dealer ( Ford ) parts when I did it ......Was like 400 bucks with my trade price ....with coolant and DCA ....
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #4 of 7 (permalink) Old 11-08-2012, 02:48 AM Thread Starter
1997 F350 CCLB
I have found a water pump without the bolt on down elbow, its all one piece. Its not cheap, but I think it will be a good and not prone to leaking. I am going to buy the 203 degree thermostat as well. But then again I work at a ford dealership and can get water pump, thermostat, tensioner, idler, and some coolant for about 391 dollars!! It will all be motorcraft. So I might go that route as well.
teevo20 is offline
post #5 of 7 (permalink) Old 11-10-2012, 12:42 AM
Am I missing something here? My NAPA pump was all one piece. Only bolt on part was the upper pipe where the thermostat houses.
post #6 of 7 (permalink) Old 11-10-2012, 01:54 AM Thread Starter
1997 F350 CCLB
They must have updated all the NAPA ones!! Thats a good thing you mentioned that!! All the ones I have been looking at online have been the bolt on style.
teevo20 is offline
post #7 of 7 (permalink) Old 11-10-2012, 02:23 AM
I think I gave around $180.00 for it.
