zf 5 problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-07-2012, 03:22 AM Thread Starter
Post zf 5 problems
ok im new to the forum and i hope for some help i have a 94.5 f350 7.3 dit zf 5 bw 1356 87 and change original miles and my problem is that the truck grinds when going into reverse i have replaced the master and the slave and has been gravity bled a few times i have also redone the pin on the pushrod this truck has sat for a year before i got it and with snow coming i need reverse to plow driveways the only way i am able to go into reverse is to shut the truck off or already be rolling backwards all help will be very appericated thank you
glenn is offline
post #2 of 10 (permalink) Old 11-07-2012, 03:30 AM
Re: zf 5 problems
You need to check the plastic bushing where the rod from master cylinder connects to the clutch pedal.
'96 F-250 CCSB 4X4, E4OD
S&B intake
MBRP 3" downpipe and 4" exhaust
Dana 60 front axle, 4" lift
N-Fab nerf bars
84mudder is offline
post #3 of 10 (permalink) Old 11-07-2012, 03:37 AM Thread Starter
Re: zf 5 problems
took that pin out seeing as how half of it was worn and ready to break so now a 1/2 in piece of round stock in there no movement at all at the push rod
glenn is offline
post #4 of 10 (permalink) Old 11-07-2012, 03:39 AM
welcome sounds like your clutch is not fully disengaging
have you checked the bushings in the clutch box, the master cyl rod end and the lever where it connects to the shaft that goes threw the clutch box it don't take much slack in any of these to lose enough throw to not fully disengage the clutch
Sent from my SCH-I500 using AutoGuide.Com Free App
slandry786 is offline
post #5 of 10 (permalink) Old 11-07-2012, 03:43 AM Thread Starter
Re: zf 5 problems
everything inside the cab is nice and tight
glenn is offline
post #6 of 10 (permalink) Old 11-07-2012, 07:22 AM
Re: zf 5 problems
First, you need to fix your period and shift keys.
Next, you need to determine whether it's the hydraulics or the clutch itself that are inop. Get an assistant to work the pedal, and slide under the cab and measure how far the end of the fork moves as they work the pedal. It should be 1/2" - 9/16". If it's at least that, then the problem is "downstream" of that point - bent/damaged fork, pressure plate fingers, etc. If it's less, then the problem is upstream - bushings, etc. in the cab, or hydraulics. The hydraulics are a b!+c# to bleed; generally if you're going for a new master and slave, it's cheaper and more reliable to install a complete pre-built pre-bled master-line-slave assembly.
madpogue is offline
post #7 of 10 (permalink) Old 11-07-2012, 09:14 AM
Binder man's Avatar
Re: zf 5 problems
Only grinds into reverse? Not hard to get into any other gears?
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
04, red regular cab, six speed, Edge SOLD
97, silver regular cab 300/200 s300
Binder man is offline
post #8 of 10 (permalink) Old 11-07-2012, 09:45 AM
STILL LEARNING
Bradbilt's Avatar
Re: zf 5 problems
If just gringing into reverse, synco is bad. Typical on a snowplow truck that is CONSTANTLY going forward and backward
Bradbilt is offline
post #9 of 10 (permalink) Old 11-07-2012, 10:53 AM
Bleeds IH Red
6.9PoweredScout's Avatar
Re: zf 5 problems
put it in second to stop the transmission from spinning then go into reverse. that's what i do on my 4 speeds.
-Jon
1980 IH Scout Terra
6.9L
1971 IH Travelette Crew Cab
DTA466 swap.
1991 F350 CCLB DWR 7.3L Banks Sidewinder/ E4OD 2WD
6.9PoweredScout is offline
post #10 of 10 (permalink) Old 11-08-2012, 03:41 AM
ved0303's Avatar
Re: zf 5 problems
I'd say the syncro for reverse is bad if it shifts through the other gears fine
1997 F250 HD, E4OD to ZF5 conversion, warn manual hubs, otherwise stock for now...
ved0303 is offline
