EBPV help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-07-2012, 01:02 AM Thread Starter
Jeffro92's Avatar
EBPV help
My EBPV is sticking on cold mornings and the shop foreman at my local dealership told me its normal and so did a lot of people on here. I'm doing glow plugs this weekend and while im in there i wanna wire it up. What's the best way to do it and am i wiring it open or shut? And how do i know when its open or shut? Thanks, Jeff
Jeffro92 is offline
post #2 of 11 (permalink) Old 11-07-2012, 01:11 AM
Re: EBPV help
just unplug it
gsxr1216 is offline
post #3 of 11 (permalink) Old 11-07-2012, 01:18 AM
spectreblazer's Avatar
Re: EBPV help
x2
try unplugging it first and that should fix it.
however on mine it would stick even when the electrical plug was disconnected. if yours does that you can disconnect the rod that connects to the valve and wire it up.
1997 F250 powerstroke
spectreblazer is offline
post #4 of 11 (permalink) Old 11-07-2012, 01:29 AM
biggreen96's Avatar
Re: EBPV help
Your going to want to wire it in the open postion. If not it could shut closed on you and give you a bunch of grief.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #5 of 11 (permalink) Old 11-07-2012, 01:49 AM Thread Starter
Jeffro92's Avatar
Re: EBPV help
Ok thanks guys. Which position is open and what is the best way to wire it open? I wanna unplug it too but I really don't want it to shut and screw me over.
Jeffro92 is offline
post #6 of 11 (permalink) Old 11-07-2012, 01:54 AM
Re: EBPV help
Unplug it first, it will be in the open position.
countryboyrob is offline
post #7 of 11 (permalink) Old 11-07-2012, 02:41 AM Thread Starter
Jeffro92's Avatar
Re: EBPV help
Ok so just unplug it and wire it how it sits when the truck is off?
Jeffro92 is offline
post #8 of 11 (permalink) Old 11-07-2012, 04:25 AM
biggreen96's Avatar
Re: EBPV help
Yep that's it.
96 cclb f350.
idm mod,
afe stage 2 intake
srp1
intercooler
238/100
dp-tuner f6
T-4 mount and s470.
post #9 of 11 (permalink) Old 11-07-2012, 04:39 AM
Mine was shuttin on and off tonight but I didn't warm it up had to make a real quick run but mine works ok at 285k and countin
strokermax is offline
post #10 of 11 (permalink) Old 11-07-2012, 02:55 PM
csp
Re: EBPV help
It can't close if it's unplugged. It has to have power to close.
csp is offline
