Dana 60 to Dana 80 conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-05-2012, 10:48 PM Thread Starter
oilfield trucker
zpilgeram's Avatar
Just picked up a 96 ccsb with a dana 60, I have a spare dana 80 i would like to put under it. The problem is, the dana 60 has 3:55 gears, the dana 80 has 4:10. I dont suppose there is any chance the gears will interchange between the different front ends?
96cc,lb,4x4,zf5. DIY dual filter intake, intercooled,gauges,4''down pipe, DIY front bumper/grill guard,fuel tank mod, 238cc Rosewood Diesel hybrids,6pos chip from TDP,
stealth SRP1 HPOP,Garrett GT4294 with DIY mounting kit,valair 500hp kevlar/ceramic clutch,Dual SD pumps electric fuel system with regulated return,5'' DIY Straight pipe.
zpilgeram is offline
post #2 of 5 (permalink) Old 11-05-2012, 10:52 PM
csp
Re: Dana 60 to Dana 80 conversion
No chance at all. The Dana 80 gears are much bigger than the D60.
csp is offline
post #3 of 5 (permalink) Old 11-08-2012, 01:55 AM
Brian
Orangeracer's Avatar
Send a message via AIM to Orangeracer
What has a Dana 80 front axle ?
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Orangeracer is offline
post #4 of 5 (permalink) Old 11-09-2012, 06:12 AM
crazed & deranged farmer
NutFarmer97's Avatar
I was gonna ask the exact same thing! or is it the rear axle you are talking about? I know these came stock with a ford rear end not a dana...
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
post #5 of 5 (permalink) Old 11-09-2012, 02:46 PM
csp
There are specialized conversion companies that will convert something like an F650 to 4x4 and use the Dana 80 in a front application.
csp is offline
