IDI to powerstroke conversion? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-05-2012, 09:25 PM Thread Starter
joemx611's Avatar
i have a 94 7.3 IDI and i want to convert it to the powerstroke engine and i just had a couple quick questions about it. first off i know the transmission will mount up (so ive been told) but are the motor mounts the same? am i gonna find myself in a wiring nightmare or does it all pretty much just plug and play? am i gonna have to do any fabrication? and last i found a 95 ambulance with roughly 290K and it has new heads because i guess one cracked and the guy rebuilt in all.. the ambulance has front end damage but he says it still starts right up he just doesnt want to fix it.. he is asking 1300 for the whole thing.. is it worth getting into or should i just go a different route? any input would be great
08 6.4 king ranch 4 door long bed, play truck with all the goods
05 6.0 single cab flatbed, bullet proofed work truck
joemx611 is offline
post #2 of 13 (permalink) Old 11-05-2012, 09:29 PM
Bugman's Avatar
Re: IDI to powerstroke conversion?
You are going to need everything from a Powerstroke truck from the dash to the radiator. All wiring, fuses, sensors, PCM, and IDM along with the pedal assembly.
Has it been done? Yes, it has but with a lot of work.
Bugman is offline
post #3 of 13 (permalink) Old 11-05-2012, 09:34 PM
pappa b's powerstroke's Avatar
this will be a big job.....you need a lot of patience to pull this off!
2002 f350 srw automatic 3:73 gears,
a/c that works!
pappa b's powerstroke is offline
post #4 of 13 (permalink) Old 11-05-2012, 10:21 PM Thread Starter
joemx611's Avatar
so vbasically i need everything that connects to the motor besides the transmission cuz i have that... is there anyone who has made a thread on doing this conversion? if not maybe it would be a good time to make one!
joemx611 is offline
post #5 of 13 (permalink) Old 11-05-2012, 11:39 PM
Be better off just selling your idi powered truck and buy a psd powered truck.
countryboyrob is offline
post #6 of 13 (permalink) Old 11-06-2012, 01:17 AM
jc82chevyman's Avatar
It's not that complicated I'm doin this swap right now its just time consuming and don't listen to people who say just sell it and buy one that would be great if I was loaded but hey but yes to do it you will need everything the wiring won't be bad if you can get an entire harness and my last bit I would not attempt this swap if I didn't have both trucks sitting next to each other
jc82chevyman is offline
post #7 of 13 (permalink) Old 11-06-2012, 01:34 AM
I'm going from gas to diesel and if its anything like my swap everything pretty much goes right into place make sure to take pictures of stuff coming off the powerstroke so you know how everything is supposed to go.
96ford250 is offline
post #8 of 13 (permalink) Old 11-06-2012, 03:36 PM
I swapped mine from big block to psd its not bad as long as you have both trucks its a lot easer to find a good clean gas truck the people that have the clean psd's want as much as a new one lol
Sent from my SCH-I500 using AutoGuide.Com Free App
slandry786 is offline
post #9 of 13 (permalink) Old 11-06-2012, 03:41 PM
post #10 of 13 (permalink) Old 11-06-2012, 07:02 PM Thread Starter
joemx611's Avatar
well like i said i found an ambulance.. would i have everything i need with that to convert over? i only lean towards the ambulance because it runs and everything is there and the guy isnt asking 5-6 grand for it like everyone with a psd
joemx611 is offline
