Headlight Problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 11-05-2012, 12:01 AM Thread Starter
Headlight Problem
Hello everyone i am new to this site and not sure if this is the correct place to post this and if its not then let me know, bot here is my problem i was taking out the isolation module and all the wiring that is for the plow because i bought the truck with no plow and have no plans of plowing with it. I got everything out but know the headlights are not working i am not sure where the stock plug in for the harness is or do i have to keep the isolation module in?
Thank you
NHstroker is offline
post #2 of 9 (permalink) Old 11-05-2012, 12:48 AM Thread Starter
Re: Headlight Problem
I guess what i need to know is where the headlight harness plugs into to get power if the isolation module is not there, anyone?
post #3 of 9 (permalink) Old 11-05-2012, 02:22 AM Thread Starter
No one?
post #4 of 9 (permalink) Old 11-05-2012, 06:33 AM
Demon Dually
speeddemon31176's Avatar
The stock headlight sockets should have just plugged into the module for the plow system. Once you removed the module the factory sockets should work unless the plow system was of an older design where you had to wire in a DPST switch in the cab in order to switch power from the factory headlights to the plow lights. If so look for a switch mounted on the dash or possibly under it.
speeddemon31176 is offline
post #5 of 9 (permalink) Old 11-05-2012, 12:45 PM Thread Starter
Heres what was plugged into the isolation module. There are 2 of these one for each headlight. Where do i plug these into?
post #6 of 9 (permalink) Old 11-05-2012, 05:26 PM Thread Starter
Nevermind i got it all taken care of thanks for the help
post #7 of 9 (permalink) Old 11-05-2012, 05:44 PM
And it was.....? (For anyone finding this thread in a future search)
madpogue is offline
post #8 of 9 (permalink) Old 11-13-2012, 02:57 PM
I have the same problem what was it????
lmmonzon is offline
post #9 of 9 (permalink) Old 11-14-2012, 05:52 PM
Question Re: Headlight Problem
X3 on that question
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
