7.3 no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 11-04-2012, 07:06 PM Thread Starter
7.3 no start
I have a 96 ford f250 7.3 powerstroke.
This weekend i pulled the motor to put a new front case on. The case i bought was fom a 97 f250 everyone told me they were the same. there was a check valve in the 96 case but no threads in the 97 case.. so we passed it and figured it was a small change ford made. tryin to start the truck this morning my hpop resivor keeps draining. if i fill it the motor starts for a few seconds than dies. Would the vavle have any reason for this?
white96 is offline
post #2 of 31 (permalink) Old 11-05-2012, 05:00 AM
JFURNER77
JFURNER77's Avatar
Re: 7.3 no start
The lpop gear supplies oil to the hpop res. I have seen them get put on backwards.
What was the reason you needed a front cover?
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #3 of 31 (permalink) Old 11-05-2012, 02:02 PM Thread Starter
Re: 7.3 no start
the reason i needed it was i cracked it by the oil cooler. is there anyway i can tell if i put it on backwards besides rippin it back apart?
white96 is offline
post #4 of 31 (permalink) Old 11-05-2012, 02:40 PM
JFURNER77
JFURNER77's Avatar
Re: 7.3 no start
If the hpop res will hold oil but is not being refilled, then you have a poblem down below. Is there any other parts you have changed?? If it worked before, double check all your work.
post #5 of 31 (permalink) Old 11-06-2012, 04:24 AM Thread Starter
Re: 7.3 no start
only this i pulled was water pump, hpop res. hpop its self oil cooler, harmonic balancer, and the gearing behind that and te front case its self. i also changed glow plugs but thats it.. we tried starting it again tonight but nothing. is the resivor from a 96 to a 97 different? becasue the top of the case is where the resivor sits. my next thought is maybe my crank sesor is bad? i reused it but it looked ok.. it wasnt damaged.
white96 is offline
post #6 of 31 (permalink) Old 11-06-2012, 04:26 AM Thread Starter
Re: 7.3 no start
sorry about the miss spellings im on my phone nd its hard to type on the fourms it acts dumb sometimes.
white96 is offline
post #7 of 31 (permalink) Old 11-10-2012, 05:46 PM
Demon Dually
speeddemon31176's Avatar
Re: 7.3 no start
The gear behind the harmonic balancer is the lpop and if the gear is installed backward that could very well be your problem.
speeddemon31176 is offline
post #8 of 31 (permalink) Old 11-11-2012, 01:16 AM Thread Starter
Re: 7.3 no start
well i pulled off my hpop res today and cranked the motor and no oil is coming up the case.. if the lpop is on backwards will it still make oil pressure?
white96 is offline
post #9 of 31 (permalink) Old 11-11-2012, 02:34 AM
lindstromjd's Avatar
Re: 7.3 no start
Just speculating, but I think your 96 is a late model 95, and those have different front covers and different HPOP's than the 97's. You need the HPOP that matches the front cover.
1994.5 F350 Dually Crew Cab
7.3 PSD, 220k miles, ZF5 2wd, 3.55 LS
Current mods: T500, Rosewood 160/30's, Hydro-boost, 120v IDM, 6637 Intake
Mods in the works: TS-6 chip, Inter-cooler, 3" intake plenums, GTP38r, MarkFuga E-fuel
... also waiting on some free time and a few final parts for my Dana 60 straight axle swap.
lindstromjd is offline
post #10 of 31 (permalink) Old 11-11-2012, 11:02 PM Thread Starter
Re: 7.3 no start
what different about the hpop? just wondering. so should i find a 97 hpop res. too?
white96 is offline
