cold weather problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 11-04-2012, 01:27 AM Thread Starter
Deerslayer42694's Avatar
ok just a quick question i am running 15 40 oil every time i crank up i get a 1280 injector control pressure code after a couple minutes of white smoke and high idle it goes away and runs fine with less smoke and a lower idle is this because of the thick oil? is it normal?
1994 f350 4x4 5sp - 7in stacks, tymar intake, t500 hpop, edge gauges
Deerslayer42694 is offline
post #2 of 7 (permalink) Old 11-04-2012, 01:47 AM
'05 Excursion
Term3's Avatar
I use 5W40 synthetic year round. 15W40 is too heavy for colder weather.
Term3 is offline
post #3 of 7 (permalink) Old 11-04-2012, 01:27 AM
Bugman's Avatar
Re: cold weather problems
I have used 15w40 since I bought my truck brand new in 96. I have started it in temperatures from a -40 to 100 degrees and I have never had a problem. When it is cold it rattles and shakes but it starts with no problems.
Bugman is online now
post #4 of 7 (permalink) Old 11-04-2012, 06:12 AM Thread Starter
Ok thanks it starts up no problems but i was just curious of the code rattlin shakin and smoke thanks
post #5 of 7 (permalink) Old 11-04-2012, 03:19 PM
'05 Excursion
Term3's Avatar
This winter you should try a 5W40 I bet your real cold weather starts and idle would be a heck of a lot smoother.
Term3 is offline
post #6 of 7 (permalink) Old 11-04-2012, 03:44 PM
mandkole's Avatar
A little HPO system reading: HPOP Manual - PowerStrokeNation : Ford Powerstroke Diesel Forum
Its not an oil weight issue, the 15-40 is fine--need to do some troubleshooting. The 1280 is a low ICP code normally driven by a pissed ICP sensor or connector. Is there oil in the sensor plug? Could be that the sensor can no longer give good pressure feedback to the IPR and the pressure circuit is not setting itself properly with cold oil.
If you actually have low (or below commanded) ICP you'll get a 1211.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #7 of 7 (permalink) Old 11-07-2012, 02:22 AM Thread Starter
the reason i think it prolly isnt the sensors is they've been replaced within the last 6 months i only get this code right after start up then within 30 seconds to a minute it goes away. some more history... it only started doing this after i got to wyoming
