truck dies - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-03-2012, 07:48 PM Thread Starter
truck dies
Got a 95 and when driving mostly over bumps it is like someone has an on off switch that is flipped a few times then will be fine again. Some times when going slow or not on the throttle it will die and usually starts right back up sometimes though it will fire amd die and I need to hold it to the floor for a sec or 2. Guessing it has to be electrical of some sort a loose wire but where
Hit-s-pinned is offline
post #2 of 4 (permalink) Old 11-03-2012, 08:03 PM
Re: truck dies
When it starts back up again, does the WTS light come on?
When it quits, do you notice if the tach and/or speedometer needles drop to zero?
Flooring the pedal doesn't do anything while cranking.
madpogue is offline
post #3 of 4 (permalink) Old 11-03-2012, 09:05 PM Thread Starter
Re: truck dies
I have not noticed but will look when I get back to it. Well I floor it so when it fires it will rev up other wise it will run for half a second then die again but rev up and will usually stay running
post #4 of 4 (permalink) Old 11-03-2012, 10:42 PM
lindstromjd's Avatar
Re: truck dies
Check your ground wires.
1994.5 F350 Dually Crew Cab
7.3 PSD, 220k miles, ZF5 2wd, 3.55 LS
Current mods: T500, Rosewood 160/30's, Hydro-boost, 120v IDM, 6637 Intake
Mods in the works: TS-6 chip, Inter-cooler, 3" intake plenums, GTP38r, MarkFuga E-fuel
... also waiting on some free time and a few final parts for my Dana 60 straight axle swap.
lindstromjd is offline
