glow plug relay question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 11-02-2012, 11:58 PM Thread Starter
1997 f350 i put a new gpr on today napa gpr 109 when key is off it has power to one of the large lugs only. When i turn the key on one large lug and both small lugs have power. any help would be appreciated.
drake162 is offline
post #2 of 17 (permalink) Old 11-03-2012, 12:07 AM
Bugman's Avatar
Re: glow plug relay question
The relay gets its ground from the PCM so if you have power to both of the small lugs the PCM isn't sending the ground signal. This can be caused by a few problems. A broken wire from the PCM, sensor proplem, or a bad PCM.
Bugman is offline
post #3 of 17 (permalink) Old 11-03-2012, 12:29 AM
ajfetterman's Avatar
X2
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
ajfetterman is offline
post #4 of 17 (permalink) Old 11-03-2012, 01:32 AM
Does the WTS light come on?
madpogue is offline
post #5 of 17 (permalink) Old 11-03-2012, 01:38 AM
Should ask how long it lights up. Mine comes on but only for a few seconds. My PCM needs replaced, it does not send (ground out) signal to my relay. I have it bypassed to a button in the dash. However my light always lit, just not long.
1988 Camaro Iroc Z
~Andy~
post #6 of 17 (permalink) Old 11-03-2012, 01:40 AM
The WTS light and the glow plugs are on two separate programs in the PCM, but both run times are driven by the EOT sensor. Before condemning the PCM, that would be the first place to look.
madpogue is offline
post #7 of 17 (permalink) Old 11-03-2012, 01:45 AM
Motherfu$&er!!
I have been.... Ok calm down. When I had everything connected factory, it was narrowed down to either a broken wire or PCM. I never found a broken wire.
At no time was the EOT ever, ever mentioned. The testing was done at the relay.
1988 Camaro Iroc Z
~Andy~
post #8 of 17 (permalink) Old 11-03-2012, 01:55 AM
If it was, in my case the EOT wouldn't I have other issues as well? I don't seem to have other issues associated with that sensor.
1988 Camaro Iroc Z
~Andy~
post #9 of 17 (permalink) Old 11-03-2012, 03:12 AM
Bugman's Avatar
Without checking wiring diagrams and reading a couple of books I believe that is all the EOT sensor does is notify the PCM of the need for the plugs.
If all else fails the simple solution to it is to pick up a push button switch and wire a ground to it and then to the ground side of the relay. When it is cold push the switch in for around 30 seconds and then start the truck.
Bugman is offline
post #10 of 17 (permalink) Old 11-03-2012, 03:14 AM
This is what I did.
1988 Camaro Iroc Z
~Andy~
