Oil sitting in turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-01-2012, 08:58 PM Thread Starter
StrokinSince97's Avatar
Can somebody tell me if this is a major problem removed my intake a noticed a little oil sitting on the bottom of the turbo inlet and also oil on the little pipe coming out that the intake connects on (sorry dont know the name its in the picture) Is oil in these areas a bad sign? From what I can tell turbo seems good and fins in it seem tight. Truck seems to run fine but I have noticed some light blueish white smoke on startup on these cold mornings and did'nt know if this could be something to do with it ?
StrokinSince97 is offline
post #2 of 5 (permalink) Old 11-01-2012, 09:05 PM
whistle tits
ghohouston's Avatar
Re: Oil sitting in turbo?
Your crank case vents into your intake, this is why youre seeing the oil. If you dont like it, re route your ccv
ghohouston is offline
post #3 of 5 (permalink) Old 11-01-2012, 09:34 PM Thread Starter
Is this normal then ?
post #4 of 5 (permalink) Old 11-01-2012, 09:41 PM
Yes, normal
02 f250
countryboyrob is offline
post #5 of 5 (permalink) Old 11-01-2012, 09:45 PM Thread Starter
Thank you had me worried at first
