truck wont start! need advice - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-01-2012, 03:21 PM Thread Starter
PSN local
SouthJerseyStroker's Avatar
so the other morning i went to start my truck and it was dead. i tried jumping it and it started to turn over once and then it ran dead again. i plugged a charger on the batteries and it read 95% on each one. i put the charger on the "engine start" setting and when it said "ready" i tried to start it and something is just clicking really loud. im not real familar with all this stuff and im baffled. it wouldnt even try to turn over after letting it sit with jumper cables to another truck for 15 minutes.
maybe its the alternator or starter? i dont really know
any advice? can i hook the cables up to something else besides the batteries?
97 7.3
PHP Phoenix
IDM mod
AFE Big Boost
06 SD rear springs
Bilstein 5100s
3" MBRP downpipe
4 inch lift
Glowshift gauges- trans temp, boost, egt
SouthJerseyStroker is offline
post #2 of 2 (permalink) Old 11-01-2012, 06:48 PM
Re: truck wont start! need advice
The 95% doesn't mean anything unless you disconnected one of the battery negatives, and checked each battery in isolation.
If it turned over a little, then you're probably not looking at a seized engine. Try this - Put the charger back on it in "start" mode. If it's a 5-speed truck, set the parking brake (or chock the wheels very securely) and MAKE SURE the transmission is in NEUTRAL (if it's a 4x4, put the t-case in neutral, just to be doubly sure). Then get a jumper cable and connect the two "big" terminals on the starter relay (on the passenger side fender). You don't even need the key to be on for this. If that makes the engine crank, then the relay is a prime suspect. If it still doesn't, then check the main battery/starter wiring / connections - connections at the battery, battery grounds, connections at the starter.
I can't over-emphasize, doing the relay jumper thing, if it's a manual transmission truck. Be DOUBLY, TRIPLY sure that the transmission is in NEUTRAL. A guy in the next town failed to do that recently, and when he jumped his starter, it ran the engine and "drove" the truck, pinned him and killed him.
madpogue is offline
