Cuts out while driving. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-01-2012, 01:06 PM Thread Starter
Im working on a 1995 with an auto trans. When you get in the high RPM's (anything above 2000) the truck with briefly cut out and return to normal. It happens so fast, the ford scan tool doesn't capture it. Its enough to notice while your driving tho. seems worse under load but it will do it in park just raising the RPM. I have replace the IPR the ICP sensor and the wiring connector to the sensor. No change in the symptom. any ideas?
1995 f-250 4x4 5 sped
4in lift,35in tires, 6637, FPR shim, Solid axle, Warn hubs, D66, PHP tunes, Hood stack, Weight box,
traction bars, rust, dents
Late 99 ext cab short bed. 388,000 miles
T500, Full Force Diesel 238/100's
Regulated fuel Return, 38r, ISS Pro gauges
5' exhaust, Riffraff diesel 6637 intake, Gearhead tunes
FordTech570 is offline
post #2 of 8 (permalink) Old 11-01-2012, 03:08 PM
whistle tits
ghohouston's Avatar
Re: Cuts out while driving.
Cps sensor/ idm?
ghohouston is offline
post #3 of 8 (permalink) Old 11-01-2012, 07:31 PM Thread Starter
I thought about the cps also. I played with it some more today and noticed it seems to get better when the engine is warmed up. How do you go about checking an IDM if there are no codes? I have never dealt with it.
post #4 of 8 (permalink) Old 11-02-2012, 04:58 AM
Demon Dually
speeddemon31176's Avatar
You need special equipment to actually check an IDM properly that the average tech wouldn't know how to use. The easiest way to verify an IDM issue is to temporarily swap it out with a known good unit and see if the problem goes away. When you say the truck cuts out do you mean the engine stalls or does it attempt to return to idle? It could be as simple as a faulty TPS or it could be as complex as an issue somewhere it the high pressure oil system.
speeddemon31176 is offline
post #5 of 8 (permalink) Old 11-05-2012, 01:14 PM Thread Starter
I work at a dealership, so we should have the equiptment. I found the cam position sensor was shorting v-ref and throwing off all the values any 3 wire sensor was reading.
post #6 of 8 (permalink) Old 11-05-2012, 01:26 PM
I went through the same with my 97 F350. I called the symptom a "hiccup" because it shut down and picked back up so quickly. Replaced the cam Position Sensor and cured the hiccups.
bushhogger is offline
post #7 of 8 (permalink) Old 11-06-2012, 04:29 PM Thread Starter
I like that term haha I'll remember that
post #8 of 8 (permalink) Old 11-10-2012, 05:39 PM
Demon Dually
OK you will need an oscilloscope in order to view the wave sin and determine whether or not you are getting a proper signal at each parameter you check. What dealership by the way. My local dealership shut the doors and now I need a new place for parts.
