dana 60 carrier pin question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-01-2012, 05:16 AM Thread Starter
pullinstroker97's Avatar
I just picked up a dana 60 for cheap, and pulled the front cover and looking at the carrier realized there is no bolt to hold the pin into the carrier, anyone know if there is supposed to be one? I would assume so
97 f250 5speed, extended cab long box, ts chip with wildman tunes, modded IDM, 3in dp 4in exhaust, 6.0 IC, Valair dual disk clutch, Beans fuel system, short throw shifter, tuff country ladder bars
Built not bought
2008 F350 6.4 stock
pullinstroker97 is offline
post #2 of 4 (permalink) Old 11-01-2012, 05:20 AM
Demon Dually
speeddemon31176's Avatar
Re: dana 60 carrier pin question
Is the bolt missing or did someone break it off trying to remove it. It is pretty common for it to break if the pin got tweaked at all.
speeddemon31176 is offline
post #3 of 4 (permalink) Old 11-03-2012, 03:52 AM Thread Starter
i can stick a pick all the way into the pin a ways, and it doesnt look like threads were pulled
Built not bought
2008 F350 6.4 stock
post #4 of 4 (permalink) Old 11-05-2012, 05:55 AM
Demon Dually
Then the bolt is just plain missing in action for some reason. The pin needs to be in there to keep the spider gears in place. The bolt is supposed to be there in order to keep the pin in place.
