97 F350 Missing in Cold Weather - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-01-2012, 01:28 AM Thread Starter
I have noticed on the 7.3 that I recently bought, when it is cold in the morning, it seems that when I start to drive at low rpms it seems to have a slight miss until it is warmed up. Is this a result of less backpressure from a straitpipe?
jmguyas is offline
post #2 of 3 (permalink) Old 11-01-2012, 01:47 AM
Bleeds IH Red
6.9PoweredScout's Avatar
Re: 97 F350 Missing in Cold Weather
mine does the same. i think it's an electronic diesel thing as non of my mechanical diesels ever did it.
-Jon
1980 IH Scout Terra
6.9L
1971 IH Travelette Crew Cab
DTA466 swap.
1991 F350 CCLB DWR 7.3L Banks Sidewinder/ E4OD 2WD
6.9PoweredScout is offline
post #3 of 3 (permalink) Old 11-03-2012, 06:17 PM
whistle tits
ghohouston's Avatar
Your truck being straght piped will not ever cause you a problem. You need a scanner to.see whats wrong, but a few things could be, dirty fuel filter, fpr screen dirty, bad injector, bad uvch... You see why you need a scanner
ghohouston is offline
