Glow Plug problems!!!!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-31-2012, 02:32 AM Thread Starter
1997 F350 CCLB
Well my truck was starting hard. So I checked my glow plug relay and found it to be bad. Installed a known good one I had laying around and it started better. Then I checked my glow plugs and found cly #1 to be bad. So I removed the valve cover and UVH. I started to remove the glow plug and it was going good until I pulled it completely out, just to find the probe still in the head F***. The probe must have swelled up and got stuck, the rod that goes from the probe to the tip of the glow plug is still connected. I tried wiggling it with a pair of pliers, but didn't try too hard cause I didn't want to break it and then have to pull the head.
Do you guys have any ideas without having to pull the head off?? I can still drive the truck as is, thank god!!! Just trying to find out a way to pull it out without breaking it
teevo20 is offline
post #2 of 3 (permalink) Old 10-31-2012, 03:32 AM
Patrick Feeley's Avatar
Re: Glow Plug problems!!!!!!
Long-nose ViseGrips and some carb cleaner (or Mercury PowerTune is supposed to be good for this) and slowly work it out would be my suggestion. Cheers!
Patrick Feeley is offline
post #3 of 3 (permalink) Old 10-31-2012, 04:20 AM Thread Starter
1997 F350 CCLB
Thanks man! I read some other forums, and found vise grips in all of them haha. Dad and I went to harbor freight for some cheap vise grips, then getting my dent puller from work and some PB blaster!!! This should be interesting!!
teevo20 is offline
