hpop - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-30-2012, 11:24 PM Thread Starter
hpop
will a sd hpop fit on a obs 73 do you have to do any thing to put it on
: 97 f350 cclb drw 300,000 miles stage 2 160 100 sticks 17* hpop sd ic turbo set up off a t444e sd fuel pump ts chip cat fuel filters stage 3 ceramic clutch 410 gears 3 in down pipe to 4 in out the back 6637 air filter all the gauges fuel hpop pyro boost oil temp 50 gal fuel tank
woodking is offline
post #2 of 5 (permalink) Old 10-30-2012, 11:47 PM
whistle tits
ghohouston's Avatar
Re: hpop
Yes it will, you have to change the 2 fittings though iirc
ghohouston is offline
post #3 of 5 (permalink) Old 10-30-2012, 11:55 PM Thread Starter
Re: hpop
thank you you don't have to time it or any thing like that I don't know what iirc is
woodking is offline
post #4 of 5 (permalink) Old 10-31-2012, 12:12 AM
whistle tits
ghohouston's Avatar
Re: hpop
No you do not time it, and if I recall corrrctly is iirc
post #5 of 5 (permalink) Old 10-31-2012, 12:17 AM Thread Starter
Re: hpop
thank you
woodking is offline
