Motor died out of nowhere - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-30-2012, 10:03 PM Thread Starter
djhankspowerstroke
I have a 96 f350 powerstroke that died this morning on my way to school. When I cranked it this morning it sounded like it was running weak, but then was running fine when I got back outside. I was going about 45 and the motor died out and would not crank again. My fuel filter and water in fuel lights came on. I drained some fuel out of the bowl, but it didn't help. I change the cam
shaft sensor and the number 22 fuse and it cranked back up, but the motor is skipping bad and really jumpy. Any ideas of what it may be?
djhankspowerstroke is offline
post #2 of 8 (permalink) Old 10-30-2012, 10:45 PM
Patrick Feeley's Avatar
Re: Motor died out of nowhere
Is the check engine light on? Check the oil level. Check the wiring harness connections at the valvecovers for evidence of melting/burning. Remove the oil cap and see if it smells like burned wiring insulation. Cheers!
Patrick Feeley is offline
post #3 of 8 (permalink) Old 10-30-2012, 11:52 PM
whistle tits
ghohouston's Avatar
Maybe you drained too much diesel and got air in the fuel system, hence running like ####? And have you ever cleaned fpr screen?
ghohouston is offline
post #4 of 8 (permalink) Old 10-31-2012, 12:29 AM
Binder man's Avatar
fuse 22 is fuel heater isn't it? Maybe the heater is shorted out
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
04, red regular cab, six speed, Edge SOLD
97, silver regular cab 300/200 s300
Binder man is offline
post #5 of 8 (permalink) Old 10-31-2012, 08:27 PM Thread Starter
djhankspowerstroke
Binder man, I'm gonna have to check that because the morning it started doing it was the first really cold morning we've had this year. But once the truck is running would the heater being out still make it skip?
post #6 of 8 (permalink) Old 10-31-2012, 08:31 PM
zilla68's Avatar
unplug the heater!
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #7 of 8 (permalink) Old 10-31-2012, 08:32 PM Thread Starter
djhankspowerstroke
Zilla68, What will unplugging the heater do?
post #8 of 8 (permalink) Old 11-01-2012, 05:23 AM
Demon Dually
speeddemon31176's Avatar
It will stop fuse 22 from blowing which is also the same fuse that powers the PCM.
speeddemon31176 is offline
