Smoking on cold mornings - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-30-2012, 06:39 PM Thread Starter
Ok this will probably be a simple question for someone to answer. When its cold in the morning when I start my truck it smokes until it warms up, sometimes for 5 minutes straight, a lightesh blue. I plugged it up last night and when I started this morning no smoke at all. Even if I dont plug it in its starts right up the same as when I plug it up, but when I plug it in no smoke at all?? Any thoughts would be appreciated, thanks.
Toddpz71 is offline
post #2 of 8 (permalink) Old 10-30-2012, 07:12 PM
HP Junky
Re: Smoking on cold mornings
I would assume what you're experiencing is just the difference of starting an engine with cold combustion chambers versus fairly warm cylinders. I would start by checking your glow plug relay to ensure it's functioning as it should, one terminal should have constant 12V power while the other should have voltage when the key is turned on. If it's working as it should, you just may need a couple glow plugs replaced.
RockinJW is offline
post #3 of 8 (permalink) Old 10-30-2012, 07:23 PM Thread Starter
Not sure if this is has anything to do with the relay, but when I start my truck the voltage is low and it goes up and down up and down for several seconds like its cycling through something, not sure??
Toddpz71 is offline
post #4 of 8 (permalink) Old 10-30-2012, 07:24 PM Thread Starter
But after 10 seconds or so it stops and the voltage goes to normal.
Toddpz71 is offline
post #5 of 8 (permalink) Old 10-31-2012, 12:56 AM
Demon Dually
speeddemon31176's Avatar
Weak coil in the glow plug relay. Replace it now before you need it and it doesn't work at all. As for the smoke, it is completely normal to have some smoke for a few minutes when starting the engine ice cold. The block heater pre warms the engine which is why it doesn't smoke when starting it that way.
speeddemon31176 is offline
post #6 of 8 (permalink) Old 11-01-2012, 03:23 AM
jdeiss
had this problem with my relay also wouldn't start at all actually... i hooked up a multimeter to mine and had 12v on one side and 11.something on the other side and it still didn't work replaced it and it will start when ever but still smokes on start up could also be something with your injector o rings i have read too but could be wrong.
96 stroker 370k and counting SCLB,xlt, zf5.4.10s
6637 filter,140V IDM,ts chip,3" diamond eye dp 5" back 7in tip
glow sh*t gauges---SOLD
96strok is offline
post #7 of 8 (permalink) Old 11-01-2012, 04:09 AM
Bugman's Avatar
Just remember, when it gets cold these trucks will smoke until the cylinders get warmed up enough to burn all the fuel.
Bugman is offline
post #8 of 8 (permalink) Old 11-02-2012, 12:27 AM
jdeiss
Yes that too. Except mine burns oil
96strok is offline
