7.3 chugging - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-30-2012, 12:37 AM Thread Starter
7.3 chugging
all right guys I need some help for some time now my truck has Been chugging going down the road . I took it to the diesel shop her in town and he told me that it was the ipr so I put in a new one on that did have bad orings then he said it was the icp did that then he said it could be the pcm tryed a different one and did the uvch or some thing to do with the wires a bad spot but I can not find one tryed a diffrent idm don't have any more money to just put parts on it could it be the hpop injector orings he said that the hpo is jumping up and down like you are pushing on the gas really fast
: 97 f350 cclb drw 300,000 miles stage 2 160 100 sticks 17* hpop sd ic turbo set up off a t444e sd fuel pump ts chip cat fuel filters stage 3 ceramic clutch 410 gears 3 in down pipe to 4 in out the back 6637 air filter all the gauges fuel hpop pyro boost oil temp 50 gal fuel tank
woodking is offline
post #2 of 3 (permalink) Old 10-30-2012, 04:22 AM
jbrixen's Avatar
Re: 7.3 chugging
have the shop dead head the pump with the icp in the circuit. this will tell you if the prob is in the pump or cyl head side of things. if it is in the heads, plug off the high pressure hose one at a time and watch the pressure, this will tell you witch head is the prob child.
jbrixen is offline
post #3 of 3 (permalink) Old 10-30-2012, 09:59 AM Thread Starter
Re: 7.3 chugging
thank you
woodking is offline
