fuel being returned to already full tank causing overflow. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-27-2012, 08:38 PM Thread Starter
My95stroker's Avatar
Not sure how to best describe my problem, but I noticed fuel dripping from under my truck. I looked underneath and the fillerneck for the front tank was soaked and thats where the leak is. That tank has been full for about 3 weeks because my fuel transfere valve #### the bed. The needle indicates correct fuel level but will not draw off of the front tank. So I removed the fuel cap and fuel started to poor out. Not sure what is causing the fuel to be returned to that tank when I am drawing off of the rear tank. Then tank switch in the cab has been on the rear and was on the rear when this started. Any idea's?
My95stroker is offline
post #2 of 7 (permalink) Old 10-27-2012, 08:42 PM
Demon Dually
speeddemon31176's Avatar
Re: fuel being returned to already full tank causing overflow.
The selector valve is bad.
speeddemon31176 is offline
post #3 of 7 (permalink) Old 10-27-2012, 08:50 PM Thread Starter
Ok Thanks. I knew the selector valve was bad, but didn't know thats what would cause the back up. I'm guessing the leak just appeared today then. Thanks again.
post #4 of 7 (permalink) Old 10-27-2012, 08:53 PM
mine dose the same if I run the front tank it gose in the rear tank
: 97 f350 cclb drw 300,000 miles stage 2 160 100 sticks 17* hpop sd ic turbo set up off a t444e sd fuel pump ts chip cat fuel filters stage 3 ceramic clutch 410 gears 3 in down pipe to 4 in out the back 6637 air filter all the gauges fuel hpop pyro boost oil temp 50 gal fuel tank
woodking is offline
post #5 of 7 (permalink) Old 10-28-2012, 01:02 PM Thread Starter
Is the selector valve the same on both gas and diesel? Dealer wants $352.96. So I think I can find one in a junk yard easy enough but out of a gas truck. Obviously if they are the same I will have to flush out the gas one.
post #6 of 7 (permalink) Old 10-28-2012, 01:34 PM
Demon Dually
No they are completely different. You have to get one out of a diesel truck.
post #7 of 7 (permalink) Old 10-28-2012, 03:42 PM Thread Starter
OK I figured as much where the diesel has return lines, versus gas that doesn't.
