Smoke at start-up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-27-2012, 07:11 PM Thread Starter
Power97Stroke's Avatar
Smoke at start-up
Ok guys got a question when starting first thing in the morning white smoke and a lil blue haze , then the rest of the day all good 97 f250 4x4 7.3 5spd w/ 257.000 plus miles ,she starts and runs fine . it doesn't matter if its 0 or 100 out side. I'm thinking injectors or cups , last year i had new injectors o-rings but not new injectors
thank you for your help
Power97Stroke is offline
post #2 of 8 (permalink) Old 10-27-2012, 08:54 PM
Demon Dually
speeddemon31176's Avatar
Re: Smoke at start-up
Completely normal for a diesel to smoke some for the first few minutes or so when it is started for the first time of the day.
speeddemon31176 is offline
post #3 of 8 (permalink) Old 10-27-2012, 09:40 PM Thread Starter
ok but it seem as if i'm fogging the street for the first minutes 1 or 2 then it goes away . about 8 or 9 hours later after work the same thing .. sorry for being hardheaded , just trying to put my mind to rest.
thank you
again for your help
post #4 of 8 (permalink) Old 10-27-2012, 09:50 PM
Demon Dually
A video of what it looks like would help.
post #5 of 8 (permalink) Old 10-27-2012, 10:00 PM Thread Starter
OK
post #6 of 8 (permalink) Old 10-27-2012, 11:12 PM
whistle tits
ghohouston's Avatar
Every 7.3 ive ever seen does it eventually cold, but doing it whle hot too would lead me to think a bad injector...
ghohouston is offline
post #7 of 8 (permalink) Old 10-28-2012, 01:07 AM
Bugman's Avatar
I was on a hunting trip this last week with the temperatures dipping into the single digits and every time that I started my truck I had the blue haze for quite a while. White smoke it just unburnt fuel usually because of the cold block.
Bugman is offline
post #8 of 8 (permalink) Old 10-28-2012, 05:18 AM
theoldgirl1990's Avatar
We just had our first cold night here in Reno, Nevada. Mid 30's. Mine does the same thing, once the engine begins to warm up the smoke begins to go away. And if the truck starts fine, it is probably not a glow plug issue, but you never know.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
