97 F350 7.3 Hard brake pedal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-27-2012, 02:31 AM Thread Starter
Truck is dually with flat bed dump, 127K miles. Brakes have been fine, til today. As I left the worksite pulling loaded trailer (about 8k lbs) at first stop, the pedal was hard and I had to stand on it and use trailer brake to stop. Also no normal vacum sound. Several stops like that and then when I pushed the pedal again I heard the vacum and had normal brake. It had intermittant failure all the way home. Thank God for trailer brakes! Got in late and no time to check anything. ANY suggestions? Booster pump maybe? But why intermittant?
bushhogger is offline
post #2 of 8 (permalink) Old 10-27-2012, 03:15 AM
Bugman's Avatar
Re: 97 F350 7.3 Hard brake pedal
I'd start with the vacuum pump
Bugman is offline
post #3 of 8 (permalink) Old 10-27-2012, 04:04 AM
Demon Dually
speeddemon31176's Avatar
Your vacuum pump is dying.
speeddemon31176 is offline
post #4 of 8 (permalink) Old 10-27-2012, 01:22 PM Thread Starter
Think you're both right. I meant to say vacuum pump not booster. Guess my weak brain was thinking booster pump because the vacuum gives boost to the brakes. Did a little research and it seems to be an easy fix. THANKS!!
post #5 of 8 (permalink) Old 10-27-2012, 01:54 PM
Demon Dually
Get one from ford as the Cardone ones don't seem to last long at all.
post #6 of 8 (permalink) Old 10-27-2012, 03:19 PM
We got one from these guys: Ford Vacuum Pump - PowerStroke a few years ago, after reading about how bad the [email protected] ones are. They claim it's the same mfr as OEM, no core charge.
madpogue is offline
post #7 of 8 (permalink) Old 10-27-2012, 06:26 PM Thread Starter
Thanks. I hope the Ford "stealership" has one in stock. Truck needs to roll asap. If not, I'll put on the cardone and then get the Ford pump in hand for later. Cheaper to do that than be down the extra day or two. Have a good weekend.
post #8 of 8 (permalink) Old 10-30-2012, 01:36 AM Thread Starter
Replaced the pump today and all is well. Had to put in the Cardone. Small town and nothing else available. It may last as long as I will work this truck. At my age I don't even buy green banannas!!
Thanks Yall
