Will superduty Injectors go into an OBS? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 10-26-2012, 03:10 AM Thread Starter
I know the superduty injectors are split shots but I have an extra set laying around and i have a 97 cali edition. Would these require tuning still and would they even be worth swapping out?
Just throwing around some ideas with this..
97 F250 Cali 7.3
Intake,DP, 4" Exhaust, EBPV Delete, Stancor, Banks Piping w/ SD Intercooler.
--Dana 60 Swap--
The Red Monster is offline
post #2 of 15 (permalink) Old 10-26-2012, 03:26 AM
old Smokey's Avatar
Re: Will superduty Injectors go into an OBS?
I am running 2000 sd injectors in my obs. They do require a little more oil on start up. Other then that it runs good. I have no tuner or chip.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #3 of 15 (permalink) Old 10-26-2012, 04:24 AM Thread Starter
any performance gain?
97 F250 Cali 7.3
--Dana 60 Swap--
post #4 of 15 (permalink) Old 10-26-2012, 04:43 AM
Demon Dually
speeddemon31176's Avatar
You will have a gain in power due to the simple fact that the split shots in the SD are a larger cc injector.
speeddemon31176 is offline
post #5 of 15 (permalink) Old 10-26-2012, 05:19 AM
Terminator Nation
The California injectors are 120 cc and the ADs are 140s.
old man dave is offline
post #6 of 15 (permalink) Old 10-26-2012, 11:11 AM
Bleeds IH Red
6.9PoweredScout's Avatar
Hmmm theres some 2000 era vans in the u pull it by me, maybe I'll grab those injectors to get rebuilt...
-Jon
1980 IH Scout Terra
6.9L
1971 IH Travelette Crew Cab
DTA466 swap.
1991 F350 CCLB DWR 7.3L Banks Sidewinder/ E4OD 2WD
6.9PoweredScout is offline
post #7 of 15 (permalink) Old 10-26-2012, 02:17 PM
WidowMaker's Avatar
Is there a physical/mechanical differance between the split vs single or is it all in the electronic's????
WidowMaker is offline
post #8 of 15 (permalink) Old 10-26-2012, 04:36 PM
Demon Dually
The van up at D's up in the commercial section still has the injectors in it. The turbo and dog house and all are already gone. Should make it easy for you to get the injectors out.
post #9 of 15 (permalink) Old 10-26-2012, 08:39 PM
Bleeds IH Red
Someone was doing some sniffing. Lol I grabbed the injectors out of the truck in the ford section.
-Jon
1980 IH Scout Terra
6.9L
DTA466 swap.
post #10 of 15 (permalink) Old 10-26-2012, 09:57 PM
Demon Dually
There is a powerstroke in the truck section now??? I need to get up there and grab some stuff. Thanks for the heads up.
