Are 7.3 blocks THAT prone to cracking? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-26-2012, 03:02 AM Thread Starter
444CuiOBS's Avatar
I know that the 96's had a short rash of blocks cracking which were often stitched by Navistar under warranty. I've also read a few threads about blocks from about 12/97 to 2001 cracking along the freeze plugs. Well, all this has me paranoid....just looking for your guys opinions on this.
I personally have never heard of anyone around here with a cracked block. All I generally here is that the 7.3 lasts as long as the 6BT (53 block being the exception) when stock or very mildly tuned.
1997 Ford F250HD XLT SC, Tymar. Edge CS. Ford shim. DP to 4" straight. 140,000mi Cooper STT 305's Just finished cab/box off resto
444CuiOBS is offline
post #2 of 6 (permalink) Old 10-26-2012, 03:47 AM
co04cobra's Avatar
Re: Are 7.3 blocks THAT prone to cracking?
You have a better chance of being struck by lightning or winning the lottery then getting a cracked block. Run the #### out of it and enjoy.
00 f250 some stuff done always more to do.
Best advice I have seen on here "If you cant afford to build it right you certainly cant afford to build it twice"
co04cobra is offline
post #3 of 6 (permalink) Old 10-26-2012, 04:17 AM Thread Starter
444CuiOBS's Avatar
Ha! That's pretty much what I figured. Thanks bud
post #4 of 6 (permalink) Old 10-26-2012, 04:35 AM
Patrick Feeley's Avatar
The only ones I've heard of were the short run of 96's (and that was a factory defect). If you don't have one of those, I wouldn't worry about it (and if you did and it was fixed by IH, I wouldn't worry either). Cheers!
Patrick Feeley is offline
post #5 of 6 (permalink) Old 10-26-2012, 08:39 PM Thread Starter
444CuiOBS's Avatar
Thanks for the feedback fellas!
post #6 of 6 (permalink) Old 10-31-2012, 03:50 AM
well i just noticed my 2001 has a cracked block . between the engine mount lower bolt and pan on bolth side running the the direction of the pan. any fix or start building. and should i drive it
2001 F-250 7.3 head studs, pdr super gtp turbo, pdr feed tubes, non ebv pedestal, custom 168cc injectors, boost fooler, dp tuner, manual trany conv, spearco intercooler, pac brake, mbrp 4" exh, afe stg 2, southbend fe clutch, short throw shifter, true-trac limited slip, mag hytec cover, fabtec traction bars, steel cowl hood
camochris is offline
