Really odd electrical issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-26-2012, 02:41 AM Thread Starter
I have a '90 F350 with a '95 PSD in it. My throttle control (go pedal) wont work unless I pull the #3 fuse in the fuse panel. Its the one marked 'not used'. It starts and idles fine, but unless I pull that fuse and put it back in again before taking off I will get no throttle response. I assume its gotta be resetting something, but I am really at a loss on what to do about it. Its only a 3A fuse BTW...
C bar M is offline
post #2 of 4 (permalink) Old 10-26-2012, 04:41 AM
Demon Dually
speeddemon31176's Avatar
Re: Really odd electrical issue
Since it is indicated that it isn't used, you will have to physically trace the wires from the back side of the fuse location to see where they go. This is the only way you will be able to figure out what they go to and in turn can help us to help you figure out what is wrong.
speeddemon31176 is offline
post #3 of 4 (permalink) Old 10-26-2012, 06:02 PM
Which fuse panel?
madpogue is offline
post #4 of 4 (permalink) Old 10-26-2012, 09:45 PM
Demon Dually
Originally Posted by madpogue View Post
Which fuse panel?
He is referring to the one under the dash.
