oil pan gasket leaking again!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-26-2012, 01:07 AM Thread Starter
Mike97f350's Avatar
I have a 97 F350 260K 5spd. I have been reading this forum for the past year and did everything right when I sealed the pan. I pulled the motor, flipped it upside down, cleaned everything with brake cleaner, and used the gray ford sealer. I have started the truck three times since putting motor back in. No leaks the first two times. Today it developed a massive oil leak rear and moderate one at the front, nothing on the sides. Only mods are 3in down pipe and ebpv delete. Any ideas??
97 F 350 CCLB DRW, 3in dp to 5 inch Diamond Eye, zf5, 4wd conversion, intercooled, 315/75/16's
E99 F 350 CCLB 4X4, Diamond Eye 5 inch exhaust, boost, pyro, oil temp, zf6, 6637, PHP Hydra, lifted on 35's, Valair clutch
09 Harley Ultra, Rush pipes, Stage 1 tune
Mike97f350 is offline
post #2 of 7 (permalink) Old 10-26-2012, 01:19 AM
STILL LEARNING
Bradbilt's Avatar
Re: oil pan gasket leaking again!!!
Front and rear main
Bradbilt is offline
post #3 of 7 (permalink) Old 10-26-2012, 01:21 AM
bracketracer's Avatar
Too much blowby maybe? Plugged CCV?
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #4 of 7 (permalink) Old 10-26-2012, 01:32 AM Thread Starter
Mike97f350's Avatar
Mains are good. I was thinking plugged CCV. I flipped the oil cap and it just vibrated off. I have been seeing some white smoke from dipstick and filler cap if I remove it. It just sucks I have to pull the motor again to reseal the pan.
Brad I have been watching your build. Awesome truck.
post #5 of 7 (permalink) Old 10-26-2012, 04:26 AM
Demon Dually
speeddemon31176's Avatar
It sounds like either you have/had a blockage in the CCV or perhaps you had just enough pressure to find two locations where perhaps the sealer didn't adhere to the block or the pan. Are you sure that the surfaces were free of contamination when you sealed it? If there was any residual brake cleaner present then the sealer will not adhere to the surface.
speeddemon31176 is offline
post #6 of 7 (permalink) Old 10-26-2012, 12:29 PM Thread Starter
Mike97f350's Avatar
I cleaned it multiple times and used compressed air to blow it dry. I don't know what went wrong. I'm hoping I can find blockage in the CCV.
post #7 of 7 (permalink) Old 11-08-2012, 02:00 AM
Brian
Orangeracer's Avatar
Send a message via AIM to Orangeracer
I no exactly why I just had same problem ! The back corner has a little lip the oil pan catches clean it With 2+2 an Rtv It
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Orangeracer is offline
