7.3 first startup - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-24-2012, 03:14 AM Thread Starter
Question 7.3 first startup
my 96 obs powerstroke's engine was worn out and I found a guy with an engine for $600. I have it all put in and buttoned up, about ready to fire off but the engine hasn't been ran in about 2 years it turns over freely with a wrench on the crank bolt (haven't tried the starter yet) but is there anything special I should do before I actually try to start it?
Thanks
Parts guy is offline
post #2 of 7 (permalink) Old 10-24-2012, 03:25 AM
old Smokey's Avatar
Re: 7.3 first startup
If you can crank it over until you get good oil pressure to the turbo, injectors, hpop ext. I think you can pull the maxi fuse for the computer. Good oil pressure to the engine after sitting should keep anything from sticking on first start up.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #3 of 7 (permalink) Old 10-24-2012, 03:28 AM Thread Starter
so its the same principal as if you had just did an injector change?
post #4 of 7 (permalink) Old 10-24-2012, 08:10 AM
Demon Dually
speeddemon31176's Avatar
Yep basically.
speeddemon31176 is offline
post #5 of 7 (permalink) Old 10-25-2012, 05:12 AM Thread Starter
ok thanks guys!! I'm hoping this engine works out. I'm ready to start the "upgrading" process!!
post #6 of 7 (permalink) Old 10-25-2012, 02:22 PM
Demon Dually
Time to open up your wallet and be poor like the rest of us.
post #7 of 7 (permalink) Old 11-02-2012, 03:45 AM Thread Starter
