96 f350 wont start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-23-2012, 07:25 AM Thread Starter
Angry 96 f350 wont start
Anyone that can help me out i would appreciate it. I have a 96 f350 and recently died on me while i was driving. I plugged in my programmer and it retrieved a code saying Camshaft Sensor error, so i replaced it and turned it on at first try after that. I drove it about 10 miles then parked it outside my house. Next morning i try n turn it on and after a few tries (i would say about 47 degrees outside) it turned on then right off. The programmer told me it was the camshaft sensor again and now replaced it again and it wont start. Has anyone experienced this or know of anything that could be wrong? any suggestions or help would be highly appreciated. Thanks
wrkoutaholic71 is offline
post #2 of 4 (permalink) Old 10-23-2012, 01:37 PM
Re: 96 f350 wont start
What brand of CPS did you install?
Did you check the wiring between the CPS and the PCM? Also the connector to the PCM?
madpogue is offline
post #3 of 4 (permalink) Old 10-23-2012, 08:42 PM
Demon Dually
speeddemon31176's Avatar
speeddemon31176 is offline
post #4 of 4 (permalink) Old 10-23-2012, 08:52 PM Thread Starter
I have the blue cps I got it from the ford dealership. An no I didn't check the cable but good point. I'll have to check it out and go from there. Thanks
