Oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-23-2012, 04:31 AM Thread Starter
Wardy70's Avatar
Oil leak
I have a oil leak that is driving me nuts. It looks like it is coming from the back of the motor around the valve cover and leaking down the side of the block. I have already switched valve covers and gaskets, did my turbo O rings, and did a ebpv delete. It is a pretty good leak, dripping off both sides of the block. The valley by the fuel pump is bone dry. Any ideas would be appreciated. Thanks
97 auto 333000 miles
TS chip,transgo tugger, billet converter,3" downpipe, diy intake, Super 66 turbo, Rosewood stage 1s. Modified hpop.
97 5 speed 250/100 injectors, 3"downpipe, Tony Wildman tunes, D60 conversion. Sold
99 Auto 238/80 full force injectors, modified 17 hpop, billet d66 turbo, beans sump in tank
Wardy70 is offline
post #2 of 7 (permalink) Old 10-23-2012, 08:38 PM
Demon Dually
speeddemon31176's Avatar
Re: Oil leak
There are two plugs, one on each head at the very back of each head that have o-rings that tend to leak and cause that problem. They are sort of hidden by the up pipes.
speeddemon31176 is offline
post #3 of 7 (permalink) Old 10-24-2012, 05:17 AM
jdeiss
Re: Oil leak
do you have a ccv mod cause i just ran into this problem my self where my line got pinched and it was coming out the top of my dipstick tube and it looked like (from the bottom of the truck) like it was coming from the valve cover gasket.
96 stroker 370k and counting SCLB,xlt, zf5.4.10s
6637 filter,140V IDM,ts chip,3" diamond eye dp 5" back 7in tip
glow sh*t gauges---SOLD
96strok is offline
post #4 of 7 (permalink) Old 10-24-2012, 10:47 AM Thread Starter
Wardy70's Avatar
Re: Oil leak
No I do not. I've been waiting for some free time to make something up.
Wardy70 is offline
post #5 of 7 (permalink) Old 10-24-2012, 05:20 PM
jdeiss
Re: Oil leak
make sure you don't have to many bends and stuff in your lines cause i got mine pinched cause the tubing was to much of a angle and to long. whooopppsss
96strok is offline
post #6 of 7 (permalink) Old 10-24-2012, 09:28 PM Thread Starter
Wardy70's Avatar
Re: Oil leak
Anyone happen to have a part number for the O rings? Thanks
Wardy70 is offline
post #7 of 7 (permalink) Old 10-24-2012, 10:52 PM
csp
Re: Oil leak
The o-rings on the plug in the ends of the head?
There's an updated plug with the o-ring attached. That's what you should be getting. The Sticky thread (second from the top in this forum) has a list of parts numbers. It's on that thread. It's a high pressure oil rail plug or something along those lines.
csp is offline
