No boost at 2500 RPM - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-23-2012, 01:25 AM Thread Starter
ntruderrider's Avatar
Ok, I replaced the replaced MAP sensor and it has the pickup of a Prius with two fat broads (sorry). I bought a Autozone boost gauge just so I could find out what the sensor was seeing. I hooked it up and set it so I could see it from the drivers seat, I slowly ran the RPM up to 2500 and I almost got to 2PSI! now I was not expecting great quality with the gauge, but 2 PSI? I even undid the intake line between filter and turbo, nothing changed. Can someone please give me some ideas, where should I be looking?
Oh, truck now has a 3" DP to existing original Cat with 272K on the truck. It runs better with out the MAP plugged in but still no boost readings.
ntruderrider is offline
post #2 of 7 (permalink) Old 10-23-2012, 02:33 AM
old Smokey's Avatar
Re: No boost at 2500 RPM
You are still running the cat. If that cat got plugged you would have vary low boost do to no exhaust flow. Try to unhook the down pipe at the cat and see if boost comes up. Check for black soot on the up pipes at the back of the turbo or look at the exhaust manifold to block for black soot.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #3 of 7 (permalink) Old 10-23-2012, 02:40 AM
STILL LEARNING
Bradbilt's Avatar
Also, is your EBPV opening?
Bradbilt is offline
post #4 of 7 (permalink) Old 10-23-2012, 03:51 AM Thread Starter
I can see a little, barely noticible around the exhast manifold up pipe some black, on one side only. there is no other black soot anywhere, i checked really well with a mirror around turbo. The EBPV does open fully, i checked it when i installed the down pipe. next step is unbolt the down pipe at the cat, thansk for you guidence.
post #5 of 7 (permalink) Old 10-24-2012, 01:46 AM Thread Starter
well you were right, cat is plugged up, unbolted the cat and it runs like a new truck, now to fix the death wobble. Can a bad tire cause it? I switched the front and back on left side to see if that tire is the problem,
post #6 of 7 (permalink) Old 10-24-2012, 04:08 AM
7.3L F-250's Avatar
i did that for my wobble and it was still ther till i took the bad tire completly off the truck
TJ
1997 f-350 7.3 powerstroke zf-5 3:55s diamond eye 5" straight pipe and 250,000 miles and counting
1978 f-350 getting some form of diesel transplant
7.3L F-250 is offline
post #7 of 7 (permalink) Old 10-24-2012, 08:12 AM
Demon Dually
speeddemon31176's Avatar
Do a search for death wobble and you will see just how many things can or can't cause it.
speeddemon31176 is offline
