cold start question for the gurus - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-23-2012, 12:25 AM Thread Starter
95 F250 PSD - totally stock.
Last year I had a couple of burnt injector harnesses and my IDM crapped out from water in it (possibly the 2 were connected issues?)
Anyway, I sourced an IDM from a newer truck 99, I believe, fixed the harnesses, ended up removing the passenger head to extract a broken autolite glowplug from the PO (GRRRRR - it was the only autolite, all the rest were Beru) and put it all back together. I put in 8 new Motorcraft glow plugs at the time It gave me great service all through last winter and this summer. Now temps have gotten cold and it is very cranky starting up first time each day. Both batts are new and it cranks good and fast.
When I turn the key on, my WTS light comes on and I get a huge drain on the dash electrical gauge - huge, as in - same as always.
But, it cranks more than usual (but still not excessive cranking), and when it starts it is cranky and smokes up the whole neighborhood for a while.
It sure feels and smells to me like my GPs aren't getting juice, but if that is the case then where is all the juice going when I see that huge drain with the WTS light on? does the GPR suck it up somehow?
fuzzydog is offline
post #2 of 11 (permalink) Old 10-23-2012, 03:00 AM
old Smokey's Avatar
Re: cold start question for the gurus
The idm you put in is for twin shot injectors. You have single shot injectors, there could be the problem. I know you can run twin shots with a single shot idm but i don't think it works the other way.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #3 of 11 (permalink) Old 10-23-2012, 03:08 AM
STILL LEARNING
Bradbilt's Avatar
The newer IDM gives more voltage than your stock 95 and that is a GOOD thing. The IDMs from 94-03 are ALL interchangeable.
As for your "hard start" you may just have one or 2 bad glow plugs, or even a bad plug going into a valve cover gasket. You need to get out an ohm meter and check it out
Bradbilt is offline
post #4 of 11 (permalink) Old 10-23-2012, 02:52 PM
Fixing Broken Stuff
toolmangary's Avatar
^^^ Do what Brad says first, if you don't find anything wrong then your injectors are probably getting tired.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 11 (permalink) Old 10-23-2012, 08:44 PM
Demon Dually
speeddemon31176's Avatar
And here is the procedure for testing them.
File Type: pdf GB_Tech_Bulletin_103_Ford IDM_Module_Replacement.pdf (710.5 KB, 4 views)
speeddemon31176 is offline
post #6 of 11 (permalink) Old 10-23-2012, 09:42 PM Thread Starter
Thanks very much for all the info/advice. I will def get the DMM out this weekend and check things out.
If my injectors are in fact tired, can I 'upgrade' to twin shot injectors (since I already have the proper IDM)?
fuzzydog is offline
post #7 of 11 (permalink) Old 10-23-2012, 10:12 PM
Demon Dually
No you were given incorrect information as far as that goes. What you have is an IDM out of a super duty which is nothing more than a higher voltage version of the same IDM that was in your truck originally. In order to run split shot injectors you would have to have your PCM reflashed to run them.
post #8 of 11 (permalink) Old 10-24-2012, 09:42 PM Thread Starter
Thanks!
fuzzydog is offline
post #9 of 11 (permalink) Old 10-24-2012, 09:53 PM
Whoever told you that info needs to be smacked with an idm...... As do you.
02 f250
countryboyrob is offline
post #10 of 11 (permalink) Old 10-25-2012, 12:39 AM
7.3L F-250's Avatar
theres a guy running ad's here on a stock truck and stock tuning and he said the thing runs mint
TJ
1997 f-350 7.3 powerstroke zf-5 3:55s diamond eye 5" straight pipe and 250,000 miles and counting
1978 f-350 getting some form of diesel transplant
7.3L F-250 is offline
