front locking hub question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-22-2012, 11:56 PM Thread Starter
so i have been having this problem of when my hubs are unlocked and i cut my wheel hard it feels like my truck wants to go in a straight line. so i was on the beach today and i accidentally kept my hubs locked and i cut my wheel hard and the truck actually turned instead of hopping and wanting to go straight. so is it bad to keep my hubs locked and drive around??
thanks,
cam
08 6.4 120k cclb fx4 black on black 20s, dpf/doc delete,sct live wire with river city diesel tunes, blizzard 9000hd plow
96 f250 180k miles and counting 7.3l sclb 4x4 4.10s Full Force stage ones, 120v idm, 17* hpop, diamond eye 3inch dp and 4 inch duals
1931 model a pick 1200 miles
camd94234 is offline
post #2 of 9 (permalink) Old 10-23-2012, 12:04 AM
Re: front locking hub question
Sounds like the hubs were installed wrong.....
02 f250
countryboyrob is offline
post #3 of 9 (permalink) Old 10-23-2012, 12:12 AM Thread Starter
but when the hubs are in the unlocked position and 4x4 is in i can spin my rear tires... so they are unlocking am i correct?
post #4 of 9 (permalink) Old 10-23-2012, 12:17 AM
Correct but they should be binding like that when turning
02 f250
post #5 of 9 (permalink) Old 10-23-2012, 01:31 AM Thread Starter
yes that is what has be confused because shouldnt they be binding when the hubs are locked. and whats the worse thing that can happen from leaving them locked other than lowering my mpg maybe by .5 or 1
post #6 of 9 (permalink) Old 10-23-2012, 03:41 PM
csp
It turned with the hubs locked because you were on the beach. The tires aren't going to grab and hop on sand. Try it in a parking lot. It will hop and lurch.
They do this on pavement (even with the hubs unlocked) because of the Ackerman angle (or lack of actually). The stock steering is set up so that one tire wants to turn more than the other when you have it turned tight and they fight each other.
csp is offline
post #7 of 9 (permalink) Old 10-23-2012, 04:19 PM Thread Starter
i have driven around with the hubs locked and on pavement and it does not hop or bind up it just turns normally. i also have the stock ifs dana 50 in it that is getting replaced could that be 50% of the issue because my friends 1st gen dodge doesnt bind up and that has a dana 60 so i think its the pos dana 50???
post #8 of 9 (permalink) Old 10-23-2012, 04:23 PM
Administrator
Zmann's Avatar
well without the transfer case locked it won't hop with the hubs locked
you will lose some mpg and the internals and seals will be being spun if you leave em locked ,, not a big deal ,, but honestly you need to figure out WTF is causing a hop when unlocked only
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 9 (permalink) Old 10-23-2012, 04:24 PM
Administrator
Zmann's Avatar
then again if the 50 is going bye bye just do what works for now
DTR's Donation page
RIP DTR Ron
Zmann is offline
