Hard starts/hiccup when hot . - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-22-2012, 07:08 AM Thread Starter
Mullet enthusiast
Talking Hard starts/hiccup when hot .
Cold starts with absolute ease every friggin time in just a few spins of the starter but when hot becomes hard to start some what shudders the truck and will hiccup to a higher rpm and immediately drop to idle ( as well as idle is not to consistent compared to other 7.3's ive owned)may not be related but I hope it helps.
97 f350 with 242k on it was told new injectors with 12k on them where do I start?
o-rings?ipr?icp?cps?e40d?to many acronyms haha thanks !
FlatbedStroker is offline
post #2 of 5 (permalink) Old 10-22-2012, 10:15 AM
Demon Dually
speeddemon31176's Avatar
Re: Hard starts/hiccup when hot .
Get it on a scanner and see what the ICP and IPR are doing when this happens. It sounds like either bad IPR or injector o-rings.
speeddemon31176 is offline
post #3 of 5 (permalink) Old 10-23-2012, 03:14 AM Thread Starter
Mullet enthusiast
I dont have AEnext best solution?
post #4 of 5 (permalink) Old 10-23-2012, 08:34 PM
Demon Dually
Find someone on here who is near you or someone near you period with a high end scanner or take it somewhere where there is a high end scanner and find out what your percentages are. There is no way to shoot from the hip with this kind of problem without it getting real expensive really fast.
post #5 of 5 (permalink) Old 10-25-2012, 01:54 AM Thread Starter
Mullet enthusiast
true ill get that figured out and post up .
