What is the act sensor? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-22-2012, 04:29 AM Thread Starter
Oakes's Avatar
My truck keeps running like sh$t , so I scanned in an came up with cost map sensor an the act sensor. I would like to know what the heck this act sensor is. Also can somebody give me ford part numbers for these items?
99 F250 4x4 6 speed
Autometer phantom II
Diamond eye 4 inch
K&N tube with a 6637.
Powerstruck 238/100 injectors an tunes
Oakes is offline
post #2 of 9 (permalink) Old 10-22-2012, 05:13 PM
Patrick Feeley's Avatar
Re: What is the act sensor?
What were the actual codes (and what scanner did you use)? Cheers!
Patrick Feeley is offline
post #3 of 9 (permalink) Old 10-24-2012, 02:00 AM Thread Starter
Oakes's Avatar
P0107 P0113 P0344 what are these codes ? I know the first ones is something with the map sensor. The second one is that iat sensor . The last one is the cam shaft position sensor.
99 F250 4x4 6 speed
Diamond eye 4 inch
Oakes is offline
post #4 of 9 (permalink) Old 10-24-2012, 08:08 AM
Demon Dually
speeddemon31176's Avatar
So by the looks of things you have a bad CPS(change that immediately). You also have a map sensor issue(check for cracked or broken map hose line from passenger intake plenum to map sensor first). Check the IAT and make sure it is there. If you didn't install the CAI then it is possible the person who did removed the sensor.
speeddemon31176 is offline
post #5 of 9 (permalink) Old 10-24-2012, 05:51 PM Thread Starter
Oakes's Avatar
Where is that iat sensor? Would that explain the hiccups my truck has an the poor fuel mileage. Also do you know the ford part number for these things?
99 F250 4x4 6 speed
Diamond eye 4 inch
Oakes is offline
post #6 of 9 (permalink) Old 10-24-2012, 06:26 PM
Demon Dually
The IAT is going to be over by the driver side fender where the air box used to be. I haven't a clue what the ford part numbers are. For the IAT just pick one up at any parts store if you need it. If you actually need a map sensor I would try to source one from a wrecking yard first as they are pricey. For the CPS go to Ford or International to get it unless one of the vendors on here still has them available.
post #7 of 9 (permalink) Old 10-24-2012, 08:57 PM Thread Starter
Oakes's Avatar
Will a map sensor off a gas work?
99 F250 4x4 6 speed
Diamond eye 4 inch
Oakes is offline
post #8 of 9 (permalink) Old 10-24-2012, 09:01 PM
blageurt's Avatar
No
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #9 of 9 (permalink) Old 10-25-2012, 01:56 PM
Demon Dually
No it won't like mentioned above but you can temporarily unplug the electrical connector and it will run on a default value in order to see if it is actually bad. If the MAP sensor is bad and you run it with it unplugged it will run better.
