WHAT THE HELL? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-21-2012, 06:05 PM Thread Starter
Unhappy WHAT THE HELL?
I have a F250, 4" exhaust, and evo chip. my problem is the same with or without chip. I pull a trailer about 7000 lbs on the flat no problem. On any kind of upgrade say 5% I drop in speed and power. I slow down to 40-45 mph and tach at 2500 to 2800. I don't have the overdrive engaged either. It has slowly gotten worse.I've looked for exhaust leaks- none, boost is at 14,fuel pressure at 45-48 psi, oil pressure is good. New fuel filter and air filter. I've even taken it to a diesel shop and the Ford dealer and both saaid it's doing what it should. I'm sorry but I think that's BS! It does not perform likr it use to. Obviously I have something going south on me. Has anybody had this issue and what did you do to correct it?
sven is offline
post #2 of 11 (permalink) Old 10-21-2012, 07:27 PM
Re: WHAT THE HELL?
Sounds like your fuel pressure is getting weak. It should be 60 or so at idle.
glovemeister is offline
post #3 of 11 (permalink) Old 10-21-2012, 11:12 PM Thread Starter
Re: WHAT THE HELL?
That sounds a little high. I don't have the California fuel regulator which gives around 55 psi...But I can tell ya it's gonna be the next purchase. Away, I'm told it,s a little low but within "Spec"...Thanks for the thought and will put it to use this week.
sven is offline
post #4 of 11 (permalink) Old 10-22-2012, 11:09 AM
Demon Dually
speeddemon31176's Avatar
Re: WHAT THE HELL?
No 60 psi is correct at idle. If you have 45-48 psi at idle your pump is getting weak. AS for the Cali fuel pulse dampener, it is not a regulator by any means. The only regulator is bolted to the side of the fuel bowl. I would also seriously look for exhaust leaks pre-turbo. The up pipes will start to leak due to the donut gaskets and you will loose power in just the manner you describe.
speeddemon31176 is offline
post #5 of 11 (permalink) Old 10-22-2012, 01:08 PM Thread Starter
Re: WHAT THE HELL?
Thanks for the info, I will look into a new fuel pump and regulator. I've checked for exhaust leaks and can't see any residue or feel any from joints.
sven is offline
post #6 of 11 (permalink) Old 10-22-2012, 11:57 PM
Re: WHAT THE HELL?
Go e-fuel...... Skip the mechanical pump and stock fuel bowl.
02 f250
countryboyrob is offline
post #7 of 11 (permalink) Old 10-25-2012, 06:28 PM Thread Starter
Re: WHAT THE HELL?
E-fuel would be nice but not in the budget. I talked to another guy who has a 97' and his is starting to have the same issue so at least I'm not alone. Ha.
sven is offline
post #8 of 11 (permalink) Old 10-26-2012, 05:48 AM
Terminator Nation
Re: WHAT THE HELL?
The California fuel pressure regulator kit uses a different spring and seat assembly than the federal trucks, generally making 60-65 psi instead of the federal 50-55 psi. Or you could use just a BB to shim the federal regulator spring.
Uppipe leaks is a good guess for power loss. Or the op could check fuel pressure under load to see if its dropping off because of demand.
old man dave is offline
post #9 of 11 (permalink) Old 10-26-2012, 07:13 AM
Re: WHAT THE HELL?
I am fairly new to PSD's so please excuse my ignorance, but is the mech pump you ar erefering to the one near the rear of the valley right behind the fuel filter housing? What would you guys recommend for an elec. pump and approx how much $??
C bar M is offline
post #10 of 11 (permalink) Old 10-26-2012, 12:19 PM
Re: WHAT THE HELL?
yes it is and the manual one cost 150.00 dollars
97 F 350 7.3L crew cab long box 5 speed 4.11 rears 4x4
Strken is offline
