Change IPR. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-21-2012, 12:34 AM Thread Starter
Change IPR.
Going to change my IPR. Is this a difficult surgery? I have a '95 with a build date of April, '95. I do know it makes a difference on which one I buy. I've read before about needing to make a deep socket "work". Anyone's personal experience is appreciated.
msscatter is offline
post #2 of 4 (permalink) Old 10-22-2012, 01:12 AM
mandkole's Avatar
Re: Change IPR.
once you get the fuel bowl/reg assembly out, its real easy. IIRC, a standard socket will work. This is a 'kill lots of birds with one stone' deal, so do your fuel bowl cleanup, hose replacements, etc. while you're in there.
The 94-95 IPRs are different from 96-97. If you are having IPR issues, be sure that the wiring harness to the IPR is in good shape. These get hosed down with fuel/oil over the years and can come apart, often giving a poor power supply. The IPR may just need orings for hard /no start issues.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #3 of 4 (permalink) Old 10-22-2012, 01:48 AM Thread Starter
Re: Change IPR.
So, is it as simple as removing fuel bowl, draining hpop, removing and replacing? When I buy a new solenoid, will it come with everything I need to make the change?
post #4 of 4 (permalink) Old 10-22-2012, 11:01 AM
Demon Dually
speeddemon31176's Avatar
Re: Change IPR.
FWIW the last time I did mine all I needed were two boxed end wrenches. I didn't pull the fuel bowl at all. It is very tight but it can be done. The hardest part is getting the tin nut started back on.
speeddemon31176 is offline
