Valve Cover Differences - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 10-19-2012, 08:55 PM Thread Starter
jcmagone's Avatar
I read an old TSB that stated the 96's got upgraded valve covers with a new insulation. Do any of you know if there is much of difference or if they actually make a difference on sound. I love how my truck sounds until I have been riding in it on a road trip and can no longer hear my self think.
Thanks,
95' F-350 PSD, CC, 4x4, LB, srw, auto w/4:10s, Stage 1 injectors (DIY), E Fuel, 17* HPOP (mod by Joey at TE), EBPV gone, Down Pipe, Stainless Monster Exhaust, AFE intake, Techni-Cooler, 120V IDM, Sky 3" RSK, 2" add-a-leaf on rear, Bilsteins, Onboard Air, Bags Front & Rear, Weld Cheyenne 8's, BFG Mud35/12.50 on 18's
jcmagone is offline
post #2 of 17 (permalink) Old 10-19-2012, 11:16 PM Thread Starter
jcmagone's Avatar
Re: Valve Cover Differences
I just pulled the drivers side cover and noticed that it is no more than a piece of pressed sheet metal. I have had them off before but guess I never really looked at the valve covers that close. Supposedly the newer valve covers are dual layer and have insulation. Anyone know for sure?
jcmagone is offline
post #3 of 17 (permalink) Old 10-20-2012, 03:09 AM
I've read where others have sprayed bed liner on the outside with some amount of quieting success. But have not read about different types of valve covers.
Hopefully someone else will chime in...
1996 F250 CCSB, 4x4, auto PSD, stainless window vents.
Signature file limitations keep me from sharing more information. Follow this link to find my threads: D60 RSK install, Air vent cleaning, etc.
leojr is offline
post #4 of 17 (permalink) Old 10-20-2012, 03:47 AM
STILL LEARNING
Bradbilt's Avatar
I have a set off of a 99 and it is double layer
Bradbilt is offline
post #5 of 17 (permalink) Old 10-20-2012, 04:18 AM
bracketracer's Avatar
'94-'95 7.3L valve covers are the same. '96-2003 7.3L valve covers are the same. So if Brad says his '99's are double layered, then the '96's would be also. Stephen
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #6 of 17 (permalink) Old 10-20-2012, 04:58 AM Thread Starter
jcmagone's Avatar
Thanks for the help and info. I think i am going to change them out. I hope it helps some with the noise. Don't get me wrong. I love the sound of my truck until I've been on the road for several hours.
jcmagone is offline
post #7 of 17 (permalink) Old 10-20-2012, 05:04 AM
By double layer what do you mean? Any pics or they on a truck?
Got4wd is offline
post #8 of 17 (permalink) Old 10-20-2012, 05:23 AM Thread Starter
jcmagone's Avatar
From what I understand its a second layer on the underside of the valve cover with a layer of some type of insulation sandwiched inside. I think they look the same on the outside.
jcmagone is offline
post #9 of 17 (permalink) Old 10-20-2012, 05:43 AM
Here's a list of other changes Ford made to the 7.3 in '96:
http://www.thedieselstop.com/faq/949...les/961113.pdf
Hey, maybe the laminated covers AND a couple coats of bedliner spray would be the way to go?
post #10 of 17 (permalink) Old 10-20-2012, 02:42 PM Thread Starter
jcmagone's Avatar
I am going to give a set of them a try. I hope they do make a difference. Probably will be one of the cheaper mods that I have done to my truck.
jcmagone is offline
