oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-19-2012, 05:36 PM Thread Starter
jdeiss
oil leak
i have a MASSIVE oil leak from somewhere and i knew i had a oil leak from my dipstick tube and was planning on doing this one of these weekends but i keep finding something else going on... its coming from the valve cover head area. i know it could be the valve cover gasket too but its spraying a lot it found its way all the way back to my rear diff and bumper its all over. is there another area i should check out?
96 stroker 370k and counting SCLB,xlt, zf5.4.10s
6637 filter,140V IDM,ts chip,3" diamond eye dp 5" back 7in tip
glow sh*t gauges---SOLD
96strok is offline
post #2 of 6 (permalink) Old 10-19-2012, 11:09 PM
Re: oil leak
check out your oil cooler...usually it leaks until engine is warmed up....I did mine last winter...not a hard job, but access is the key....hth
'95 F250 SC 7.3 auto 4x4 long box...Rosewood stage 1's tymar intake 3"DP...Dfuser AIC... 263,000 and runnin' strong!!
mojoman is offline
post #3 of 6 (permalink) Old 10-20-2012, 01:38 AM Thread Starter
jdeiss
Re: oil leak
It's the passenger side though I think I did my CCv mod wrong and it's coming out of my dip stick tube... But sadly my oil cooler is leaking slightly too
96strok is offline
post #4 of 6 (permalink) Old 10-20-2012, 02:58 AM
19stroker97's Avatar
Re: oil leak
The ccv is on the drivers side though, so idk how it would be getting oil on the pass side. If its spraying up out of your dipstick tube then sounds like you got some blowby. I know about a month ago I had to replace my valve cover gaskets because oil was coming through the electrical fittings. Maybe check your turbo o rings too, had to replace mine when I did the vc gaskets.
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #5 of 6 (permalink) Old 10-20-2012, 03:12 AM
MOTO MANIAC
MOTO7.3's Avatar
Re: oil leak
Check to make sure that you CCV is not blocked or pinched it will come out of the Dip stick tube like a fountain if it is. Try to re install the CCV back to stock and see if that works.
The Black Sheep.
E99 F350 CCLB
5r110 trans cooler and filter.
4''mbrp, Isspro boost, trans, EGT,
S&B CAI. NO Limit tunes
MOTO7.3 is offline
post #6 of 6 (permalink) Old 10-20-2012, 04:09 AM Thread Starter
jdeiss
Re: oil leak
thats what happened was it was pinched and it is literally a fountain its everywhere. i didn't even think about it till i started tracing it back to that. newer valve cover gaskets. and it didn't start till then so i put it back to stock but ran out of time to tighten all my valve cover bolts down and now I'm out of town so I'm hoping that is what happened easy fix. thanks everyone
96strok is offline
