Over drive light started blinking.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-18-2012, 09:52 PM Thread Starter
Coueshunter's Avatar
Loaded up truck and trailer to go to Glamis. Got across town and the overdrive light started blinking. Overdrive still works with switch, any ideas?
Just turned around and headed home to switch out trucks. Would love someone to come scan my truck while I'm gone for a couple days! Help! Hoping the tranny is not headed out.
Any ideas?
Any weekday after 5pm or on say wife will be home . Or ill be there in 30 minutes.
4807214789
Deven
Back the Blue BUILD THREAD
POWERSTROKENATION-
Facebook-
Coueshunter is offline
post #2 of 7 (permalink) Old 10-18-2012, 09:59 PM
Re: Over drive light started blinking....
Without knowing the code not much we can do, what do you think your gross weight was?
02 f250
countryboyrob is offline
post #3 of 7 (permalink) Old 10-18-2012, 11:03 PM
1 Slo PoMoFo
Ranger50's Avatar
Blinking OD light = trans has a fault code. Beyond that, not much help until the code is pulled.
"Never trust an intelligent man with no money to play fair."
97 F250. 213k. Just about as stock as stock can be. Cali mod. Yard ornament.
Ranger50 is offline
post #4 of 7 (permalink) Old 10-19-2012, 12:35 AM Thread Starter
Was pulling about 8k lbs at most
POWERSTROKENATION-
Facebook-
post #5 of 7 (permalink) Old 10-20-2012, 12:46 AM
Check your fluid level first.
msscatter is offline
post #6 of 7 (permalink) Old 10-22-2012, 07:32 PM Thread Starter
pulled codes today..... Thanks to Jim.
Heres what we found.
P0470 Exhaust pressure sensor
and the tranny related
P1728 Transmission slip
We cleared the codes and took it for a drive and made an xcel file which i have no idea what it is showing. Maybe someone will. Did a couple full throttle take offs and seemed pretty good.
After clearing and driving we got a system pass
POWERSTROKENATION-
Facebook-
post #7 of 7 (permalink) Old 10-22-2012, 08:09 PM
Demon Dually
speeddemon31176's Avatar
That code is for the converter slipping usually.
speeddemon31176 is offline
