E4OD Dipstick - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-18-2012, 02:44 PM Thread Starter
Rjmorrow's Avatar
E4OD Dipstick
Does anyone have a source for a replacement dipstick, or maybe a used one laying around for an E4OD. This is out of my '97. I went to check fluid level yesterday and found that the plastic end you take readings on is snapped off.
1997 F250HD 4X4 EXT CAB, 7.3, E4od, 232k
1970 Mercury Cougar XR7, 351c
Rjmorrow is offline
post #2 of 2 (permalink) Old 10-19-2012, 06:40 PM
Re: E4OD Dipstick
E4OD Transmission One Piece Dipstick and Tube
Looks nearly the same as mine.
1997 F250 05+ Axle Swap 3.73 Home Built 4-link Front with Ballistic Parts. 2.5" Front Coils. B-code Rear. DIY Trans w/ Precision COnverter. DIY Traction Bars. TDP 6-Pos Chip BW TP38 w/ 1.00 EXH. Rosewood DIY STG1's. DIY E-Fuel w/ Dual FM100's. SD quad pod above Rearview
turboaz2 is offline
