Broke my Programmer, now what?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-17-2012, 05:05 PM Thread Starter
LBZ
LBZ's Avatar
Broke the screen on my old Micro Max Superchips programmer so now I'm stuck in performance mode-such as it is. This is fine but if I ever want to switch to a different programmer, I need to flash the truck back to stock and can't now.
Any tips on how I can get this thing flashed back to stock?
'07 Duramax
'97 Powerstroke
LBZ is offline
post #2 of 11 (permalink) Old 10-17-2012, 05:52 PM
old Smokey's Avatar
Re: Broke my Programmer, now what??
You could take it to ford and have the computer refashed. Be about 50-100$. But then the programmer would not work do to the programing not going back to stock for the superchips.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #3 of 11 (permalink) Old 10-17-2012, 06:34 PM
mandkole's Avatar
you should also be able to get one of the tuners on the site to flash the PCM for a fee...no worries
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #4 of 11 (permalink) Old 10-17-2012, 06:51 PM
Demon Dually
speeddemon31176's Avatar
A little more work but if you could get your hands on a spare PCM and throw it in till you can fix the programmer, that would work also.
speeddemon31176 is offline
post #5 of 11 (permalink) Old 10-17-2012, 09:38 PM
OBS Stroker
Nodge's Avatar
Put a ts 6 pos chip in, then it doesn't matter what's on the PCM.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #6 of 11 (permalink) Old 10-17-2012, 10:35 PM Thread Starter
LBZ
LBZ's Avatar
I contacted Thoroughbred Diesel and they said I need to flash it back to stock before I can install a TS. I'm not worried about flashing it again with the SC as I can't read the screen so it's going into the garbage as they won't fix it and want $300 for the closest thing which is an Edge Evo.
Looks like I'm gonna have to go to Ford and bend over before I go with the TS.
'07 Duramax
'97 Powerstroke
LBZ is offline
post #7 of 11 (permalink) Old 10-17-2012, 10:42 PM
They are full of ####.....
The pcm doesnt care what tune is on there as the chip will override it.
Find a paying site sponsor that actually knows these trucks before going with a cheaper place.....
02 f250
countryboyrob is offline
post #8 of 11 (permalink) Old 10-17-2012, 11:13 PM Thread Starter
LBZ
LBZ's Avatar
I didn't just go with a cheaper place. I did a google search for Powerstroke programmers and Thoroughbred was one of the first that came up. I didn't even think about vendors on here to be honest.
I sent an email to TS Perf. We will see what they say.
'07 Duramax
'97 Powerstroke
LBZ is offline
post #9 of 11 (permalink) Old 10-17-2012, 11:16 PM
Chip info
02 f250
post #10 of 11 (permalink) Old 10-18-2012, 12:50 AM
OBS Stroker
Nodge's Avatar
It doesn't matter what's on the PCM.
As rob said, the chip totally over rides what is flashed on the PCM.
Don't call TS, call one of the tuners in robs link.
Swamps, Php, beans, etc etc etc.
Myself, I liked swamps tunes on my stock 5 speed truck, but have tried a few different tuners, and they are ALL better than the stock TS tunes.
Nodge is offline
