Fuel bowl heater - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-16-2012, 01:54 AM Thread Starter
Fuel bowl heater
Looking for some input on replacing/repairing my fuel bowl heater any tips does/don't would be appreciated.
Thanks
OBSisbest is offline
post #2 of 7 (permalink) Old 10-16-2012, 04:03 AM
Patrick Feeley's Avatar
Re: Fuel bowl heater
Here goes (the basic steps):
Drain the fuel Bowl and remove the cap and filter.
Remove the black plastic standpipe using a 7/8" crows-foot wrench (note that the standpipe is LEFTHAND THREADED).
Disconnect the small spade connector inside the fuel bowl (driver's side) and pull out the heater (the plate with the wire on it ... or off it as the case may be)
Replace the heater making sure the little tab on the plate will keep the plate from rotating when the standpipe is tightened. Plug in the spade connector.
Reinstall the standpipe, filter and cap. Done!
You can also replace the normal OBS-style plate/wire with the SuperDuty-style element as it is less prone to failure (recommended). Part numbers:
Fuel Heater Element
OBS Style: (Ford) F5TZ-9J294-A (94-97), (International) 1825186C91 (may not work, need to check)
SuperDuty Style: (Ford) F81Z-9J294-AA, (International) 1831196C92, (Dorman) 904-210
(requires some minor mods to fuel bowl to remove an inner rib, but supposedly the Dorman part does not require the mod and is probably much less expensive)
Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 7 (permalink) Old 10-16-2012, 04:06 AM
Most fellas "repair" it by decommissioning it. Just unplug it. The engine was designed at a time when fuel was not nearly as stable at low temperatures as it is today, and waxing/gelling was a real issue. Nowadays, most folks just make sure they use good quality fuel, use an additive esp. in the winter, and they don't worry about the fuel heater.
madpogue is offline
post #4 of 7 (permalink) Old 10-16-2012, 03:36 PM
csp
Mine started at 19 below last winter without the heater plugged in. Mine shorted out probably ten years ago and has been unplugged since then.
As said, stick with quality fuel and you don't need it.
csp is offline
post #5 of 7 (permalink) Old 10-16-2012, 08:50 PM
OBS Stroker
Nodge's Avatar
Most guys with electric fuel conversions aren't running a heater of any kind, either. You can just unplug it, you'll be fine.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #6 of 7 (permalink) Old 10-18-2012, 02:16 AM Thread Starter
Thanks everybody for the information, not sure what Im going to do at this point as far as removing or replacing. Thanks Patrick for the part numbers a big help.
post #7 of 7 (permalink) Old 10-18-2012, 03:43 PM
csp
If you do decide not to use it, it doesn't have to be removed. Just unplug it.
csp is offline
