codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-14-2012, 08:36 AM Thread Starter
Deerslayer42694's Avatar
codes
Lately ive been gettin the 1280 code at startup but i figure its because of cold thick oil but today i got the 0340 code that deals with the cps but after a minute it went away what could cause this?
1994 f350 4x4 5sp - 7in stacks, tymar intake, t500 hpop, edge gauges
Deerslayer42694 is offline
post #2 of 3 (permalink) Old 10-14-2012, 10:18 AM
Demon Dually
speeddemon31176's Avatar
Re: codes
Either a faulty CPS or the connector or wiring to it. Most likely either a failing CPS or connector. Also another thought is that if you have extended crank times trying to start the truck you will throw CPS codes.
speeddemon31176 is offline
post #3 of 3 (permalink) Old 10-14-2012, 05:31 PM Thread Starter
Re: codes
Thanks for the info
