Truck dies when you hit the horn an wants to dies around 2500rpm - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-14-2012, 03:35 AM Thread Starter
Oakes's Avatar
Well, after I changed my lift pump my truck started dieing when you hit the horn. It also has a hiccup at around 2000-2500rpm range. What could it be I have no check engine light or codes .
99 F250 4x4 6 speed
Autometer phantom II
Diamond eye 4 inch
K&N tube with a 6637.
Powerstruck 238/100 injectors an tunes
Oakes is offline
post #2 of 5 (permalink) Old 10-14-2012, 07:55 AM
Demon Dually
speeddemon31176's Avatar
Re: Truck dies when you hit the horn an wants to dies around 2500rpm
If the truck dies when you hit the horn, what does it do when you turn on the head lights? The only correlation between the horn and the engine dying would be that the alternator is either not charging the batteries or the batteries are bad or have poor connections and the draw from the horn is pulling too many amps/volts away from the pcm/idm causing the truck to stall out.
speeddemon31176 is offline
post #3 of 5 (permalink) Old 10-14-2012, 10:21 AM Thread Starter
Oakes's Avatar
It runs like a champ even with the headlights on. I have tested my charging system it checked out fine.
99 F250 4x4 6 speed
Diamond eye 4 inch
Oakes is offline
post #4 of 5 (permalink) Old 10-14-2012, 10:27 AM
Demon Dually
Well the only thing I can possibly think of that could cause your horn to kill the truck then would be some sort of a short in the horn system. The horn ring is negative side activated which then energizes a relay that then sends 12 volts to the horn. The horn is grounded by its mounting bracket. I would check to see if there is some sort of wiring fiasco under the dash somewhere.
post #5 of 5 (permalink) Old 10-14-2012, 08:55 PM
Do either/both horns work?
madpogue is offline
